Audio by Van Alstine ABX Comparator Review
All the drama aside, Josh put as much work into this test as I've seen outside of actual scientific studies.
Which I guess exposed him to the sunk cost bias, cos getting this type of very weird results and prioritise the explanation that ''I can tell 2 Dacs appart'' shows a lack of common sense, which at first glance he doesn't seem to be deprived of.
Great review, as usual. It adds another trope in the English language...data in, garbage in between, garbage out. It shows the power of rigorous measurement protocols to lift "the veil of Maya" from our sensory experience, a deceptive illusion that hides the reality of music reproduction. Thank you Amir!
Almost 10 years ago I designed and built an AB box with much better parameters.
Where did you source that great looking, high quailty box you used for the build?
Here:
I send them dwg files to mill and cut the front and rear panel holes.
Common sense goes out the window when cognitive biases dominate. "Common sense" would indicate not bothering to do a listening test with DACs at all, after seeing the measurements. Or getting involved in subjectivist audio at all, same reason. The core problem is our hearing feels a lot more reliable than it is and leads us to all kinds of wacky conclusions if we let it.
Similarly, you can explain to someone that homeopathic stuff is literally just water, and they will understand you and agree, and then say "well, but I took it and felt better so I'm going to keep buying it". Placebo? Nah, not me! That's what happens to other people!
I'm guilty of this, and make no apologies. I don't do homeopathy (except once to humor someone), but I have seen a chiropractor and an acupuncturist. They are founded on unscientific and repudiated principles. But hey if it's covered by insurance, I'll give it a try and keep doing it if it works for me. Likewise if someone prefers the sound of adequate amp A to adequate amp B, I advise them to use adequate amp A. We can't do that much about cognitive bias, and it has a very real effect on us. I only draw the line when someone says that their personal sighted experience is evidence that adequate amp A is better in some way than adequate amp B.
I went to a chiropractor (also despite knowing better) because my back was going crazy and I'd try anything at that point. It does feel better for a little while after they do all their cracking and whatever, but longer term I think it just made things worse. I stopped going when they sent me a marketing email about bogus treatments for Alzheimer's. That was too egregious to overlook.
It's definitely very hard for the rational mind to override your sensory experiences. Hence almost every audio forum except this one...
Here are some additional tests I ran in the process of comparing inputs after level matching them relative to AP's input impedance:
As expected, noise is a serious problem as levels get smaller. Exponential rise shows that it is noise and not level deviations.
IMD test shows how quickly the AVA starts to distort and distort heavily:
There is differential impact here so the attenuator distortion is level dependent. But too small to explain clear audibility differences.
While not normative in explaining what Josh is claiming to have heard, it is clear that the AVA seriously pollutes the output of just about any DAC we talk about here. And by a huge mile. Saying that one hears differences between state of the art DACs but not some large impact on the sound itself, is non sequitur in my book. With claimed hearing ability, one should have been disgusted the moment AVA was put in the loop but no such comment was made.
One general note about JND (just noticeable) level differences. I must say, I have gained new appreciation for how good our hearing is in detecting such differential in quick AB testing. I would have never guessed that half a dB would have such massive difference. Even as I got close, I could reliably tell the sources apart. We should do some simple experiments of our own with both single tones and white noise and determine the correct level.
As is, I am worried that the 0.07 dB or so that I can't match with AVA may still be enough to tell the difference between sources. I didn't spend enough time to confirm.
As an aside, fast AB testing shows its power in the way makes such small differences so obvious.
Mostly with white noise, right?
The ABX was hard for me -- I only hear up to 13KHz. Still I thought I was hearing a difference. And midway through I felt like I was losing the ability to tell the difference, just as shown in the results. I can't imagine I would have any chance at all to tell the difference with music instead of white noise. But with these white noise files I expect someone who can hear higher frequencies could easily get 16/16.
Attached is my result - with speaker, 2-way with horn loaded compression driver tweeter.
With the original level "matching" into Topping A90, single tones easily revealed audible differences as I reported. White noise had level difference but seemingly, spectrum. In one source it sounded brighter. But I did not do my accurate level matching through A90 with noise. Ditto for my blind testing.
(Exact) Level matching is difficult or close to impossible IF the 2 components do not have flat frequency response. Both methods do fail, either single sine tones or average rms.
Not only. You may make your own noise patterns, like band-limited white noise. It is more prone to distortion than a single tone. BUT, if the comparator fails with the white noise, then it is unusable for DAC, preamp and amp testing, and may be unusable for speaker testing as well.
Let me reflect on something. When I thought levels were matched but really weren't, my listening tests alone told me something was seriously wrong. No way can you believe in any amount of science and engineering and be so comfortable that telling the two sources was this easy. At best, the differences had to be extremely hard to find. But they weren't in my case and seemingly Josh's.
So maybe he heard something else than level differences. The right step would have been a clear investigation to prove it is not the fault of the comparator and not run out and say he heard differences in state of the art DACs. As I said in the other thread, we have this ability to investigate with both tools and expertise. It is not boasting to do this. This is what we do here day in and day out. Why not use our resources to find answers?
At this point I am confident that if he heard something else, which unlike me he can't objectively articulate, we would have found the cause of that as well. Measurements and understanding of science and engineering has this power. As demonstrated now.
"Enhanced hearing" ...... I would be cautious.
Way ahead of you ;)
Using pink noise, even 0.05 dB is borderline and 0.1 dB is significant in my limited testing. In general, noise is a much better discriminator than music, though:
Note: Paper [D] in the linked post is Soulodre et al. (2003), not Scott et al..
This thread is a ride..I want to respond by asking the question: if the
Audio by Van Alstine ABX Comparator​
is a finger pointing at the moon, what is the moon?
Is it science, or profit?
I have modified my simple AB box to imitate @amirm test with white noise. This is the difference spectrum between the two channels, measured by REW frequency sweep:
Then I have recorded the white noise, once with "full range" channel, once with the LPF limited channel. The files are linked below, to make an ABX test, for those who would like to. The files can also be put into Deltawave. Please note that absolute matching is impossible due to difference in FR. Same as in the real life. Sine matching at one frequency gives different results than noise matching, for obvious reeasons.
This is the difference that REW found between the white noise recorded files:
At last, an easy one. For us "younger guys"...
foo_abx 2.2.3 report
foobar2000 v2.25.10
0126-10-05 21:34:11
File A: Lwhite.wav
SHA1: ae7f9725e87abb47f717b63b49dedd3a9b838416
File B: Rwhite.wav
SHA1: 23f9d0e148b4fd7436d713fea21ecbf1da5d86d2
Output:
Core Audio : Default, 24-bit
Crossfading: NO
21:34:11 : Test started.
21:34:44 : Test restarted.
21:34:44 : 01/01
21:35:52 : Test restarted.
21:35:52 : 02/02
21:36:06 : Test restarted.
21:36:06 : 03/03
21:36:22 : Test restarted.
21:36:22 : 04/04
21:36:32 : Test restarted.
21:36:32 : 05/05
21:36:46 : Test restarted.
21:36:46 : 06/06
21:36:58 : Test restarted.
21:36:58 : 07/07
21:37:05 : Test restarted.
21:37:05 : 08/08
21:37:12 : Test restarted.
21:37:12 : 09/09
21:37:20 : Test restarted.
21:37:20 : 10/10
21:37:28 : Test restarted.
21:37:28 : 11/11
21:37:40 : Test restarted.
21:37:40 : 12/12
21:37:48 : Test restarted.
21:37:48 : 13/13
21:38:04 : Test restarted.
21:38:04 : 14/14
21:38:13 : Test restarted.
21:38:13 : 15/15
21:38:22 : Test restarted.
21:38:22 : 16/16
21:38:22 : Test finished.
Total: 16/16
p-value: 0 (0%)
-- signature --
dd6a5f768ef159892e072e8bd0d3cab507a71672
