Audio by Van Alstine ABX Comparator Review
We need a new crisis.
This is a review and measurements of the Audio by Van Alstine (AVA) ABX Comparator. It is discontinued but I purchased it for US $1,300.
This is a multipurpose AB testing device, capable of switching and level matching both amplifiers and sources:
This it third and last known ABX comparator that I know of. Reviewer, Josh Mound used this very box to perform blind testing of a few DACs. Results were remarkable with reviewer being able to confidently tell the DACs apart going way past any conventional wisdom. With the exception of two tests which were 15 correct outcomes out of 16, the rest were 16 out of 16! As a trained listener, even when I find differences between files, it is very difficult to get such perfect scores when differences become vanishingly small.
As you can imagine, massive thread was generated on validity of the results and potential for errors that would lead to such extreme results. Ultimately though, we could not get far just reading the words of the self administrating tester. I won't bore you with the details but eventually members and I managed to purchase the comparator to test.
I am going to reveal the punchline now. Josh in his article mentions: " A small, uniform click sounds with every button press, concealing whether an actual switch has occurred." This is key as switching is done by a relay which can naturally sound different when pulled closed by a magnetic field and then let back open via a spring. One of the earliest adopters of ABX testing was the Boston Audio Society. They put a subjectivist under ABX testing with professor Vanderkooy as a guest observer. Even though the subject failed the test, Vanderkooy made this critical observation:
"I expressed my desire to try the test, and Remington went to cue up the record again, but I requested to be allowed to undertake the test with no signal passing though the system. Before realizing the import of what he was saying, Vanderkooy interjected: "Ah! You're going to listen to the sound of the relays." Yes, there is indeed a slight audible difference between the acoustic "click" made when the "A" and "B" relays pull in. This is due to the unavoidable differences in the mounting positions of the relay on the A/B/X box chassis and, although slight, it can be heard if one listens for it. I replied that I was going to listen to the difference in background hiss, and the subsequent series of blind trials showed conclusively that the two signal paths could be reliably distinguished on this basis alone."
Naturally I tested the same by pressing the 1 and 2 buttons on the remote which switch sources. The distinction was clear. In one direct the sound went "up" with more of a high frequency accent and the other more muted droop. I wanted to make sure I was right so I invited my wife to come and listen. I told her to listen to the sound and that there could, or could not be a difference. She immediately said they sounded different. Wanting to make sure I asked her what the difference was and she explained it exactly as I did! I tried recording the sound using my phone but the mic is not good enough to record the full spectrum.
Now, if you have the unit far away and using it to switch amplifiers while playing loud, you may have a hard time hearing the difference. But in close proximity, testing DACs with headphones/IMEs, it would be trivial to intentionally game the system and listen for the relay difference. The device makes this easy as you can go backward in the sequence so even if you forgot what the last relay sounded like, you can refresh your memory.
The system is simply not fit for any testing for external publishing. For your own, you can choose to block the sound and such. But as evidence of audible difference in sources at least, it is useless.
I also have to wonder how someone who says he can tell the difference between DACs can't hear differences between relay clicks!
Basically the job is done now but let's measure the thing while we have it anyway.
Audio by Van Alstine ABX Comparator Measurements
I set the level to max 99 and fed the input A 2 volts and measured output A:
I expected less than stellar performance but this is entirely too much distortion. There is also a bunch of power supply noise which I could not impact with any grounding scheme. I think in the long thread we talked about poor routing of cables and such, making the unit susceptible to noise pick up.
Yes, it is the same impact on both devices under test but surely this level of distortion easily dwarfs distortion spikes in original DACs that are orders of magnitude lower. As a way of reference, this is the dashboard for one of the DACs tested by the reviewer:
Noise performance is not bad but again not appropriate for testing DACs and some high performance amplifiers:
We were told that there were passive attenuators used for level matching. So I tested frequency response at different levels of attenuation:
If you are a young person and have to really adjust levels down, then it is possible that you can tell the impact on that source due to roughly 0.4 dB extra attenuation at 20 KHz.
I didn't see a reason to keep testing.
EDIT: I performed some listening tests and additional measurements, showing variable output impedance impacting level matching: https://www.audiosciencereview.com/...tine-abx-comparator-review.73737/post-2695263
It should be obvious that there was no reason for us to go through the expense and effort of testing this ABX comparator. There is clear mechanical noise which gives away the identity of the source. The reviewer claim that the sound is "uniform" shows either extremely poor ability to listen for differences, or dishonest reporting of the device characteristic.
Even ignoring that, the measurements show dramatic level of distortion and to some extent, noise, impacting source DACs. We are talking whopping 50 dB extra distortion! Heck, you could almost replace the comparator with a tube amp and more or less be just as badly situated. No way any characteristics of the original DAC sound is left to analyze. Any super human detection ability would be seriously offended by this massive increase in distortion. The fact that the reviewer was not experiencing such, shows lack of ability to hear clear impairments. We could use this as some kind of control and dismiss the listener as not being qualified to enter the next phase of detecting differences in DACs.
Much thanks to member @NTTY for initiating and helping fund purchase of the comparator.
Not that you could buy one but if you wanted to, better wait for the community version being designed.
I'm mystified by this device: why would anyone make something that is so specialised and intended for a highly critical market and yet have such obvious and basic failings?
The question is whether or not this device was intended for' a highly critical market' and testing 'DAC performance'.
It does not seem to be for that market but rather as a box for testing speakers and power amps and/or a combination of them.
It's tailor made for audio retailers - a box that looks impressive, seems scientific, and reliably produces a subtle yet detectable difference between components. Any competent salesperson can persuade the customer that the more expensive item is "better" if a difference can be heard.
And before somebody calls me cynical, I actually had a retailer (a dedicated hifi retailer, not Best Buy), just 1 year ago try to convince me that there was an audible difference between the optical and digital outputs of a DAC. I had to point out that the way they had it set up meant there was a daisychained set of speakers in another room playing quietly when one was used vs the other - that was the difference.
In the end that's Amir's decision though, his willingness to dig a little deeper and spend time on that... or not.
Do not you think he has already spent enough time with this mediocre unit? How many engineers does it take to argue with one incompetent, amateurish uncontrolled test and review? And why? To persuade those who cannot be persuaded?
I don't think we can conclude that - only that an audible difference has not been proven using the AVA ABX comparator.
Have you seen this thread, about comparing DACs using ADC recordings and Foobar200 ABX testing?
Yes, but again the ASR thread is mainly filter differences, at least on the devices where people can pass the ABX. I don't think everybody here thought filter differences are always inaudible. Josh was trying his best not to have filter differences because he wanted to show he could hear something else that was different.
True.. one can never persuade the ones who cannot be persuaded :) nor was that Amir's goal.
He bought it to check its performance and most of that is clear now.
How deep down the rabbit hole Amir is willing to go and how much more time he wants to invest in this flawed device is Amir's decision only.
In such cases like this failed comparator unit, white noise test, like @amirm did, is the best method.
  • connect white noise generator to one input of the AVA box
  • connect the same signal via resistor divider (or stepped attenuator) to the second input, set attenuation and then match the gain on AVA box
  • measure the FR difference
  • make an ABX test
And from what Amir has measured, I am sure many people will hear a difference. And this would completely discredit the AS review.
We can't change subjectivist audiophiles believing in their dogmas.
My interest (and why I donated towards the purchase of the ABX box) is that Amir finds out what the tell or tells that the box provides are, purely to learn something more about the pitfalls of comparative testing of audio gear.
Josh's results have always been obviously unbelievable with him getting almost perfect results. It really is not a questio that things went wrong there, just how they did.
  • make an ABX test
It may indeed do this but I bet it won’t change anyone’s mind over on AS
I have modified my simple AB box to imitate @amirm test with white noise. This is the difference spectrum between the two channels, measured by REW frequency sweep:
Then I have recorded the white noise, once with "full range" channel, once with the LPF limited channel. The files are linked below, to make an ABX test, for those who would like to. The files can also be put into Deltawave. Please note that absolute matching is impossible due to difference in FR. Same as in the real life. Sine matching at one frequency gives different results than noise matching, for obvious reeasons.
This is the difference that REW found between the white noise recorded files:
OK, we have some major discovery.
I set up Topping D70s and Matrix DAC using the same S/PDIF input coming from my Audio Precision Analyzer S/PDIF output. Hooked up the DACs to inputs A & B of the comparator and measure the output voltage. They were different. I used the trim control on AVA to get them to match to about 0.07 dB which was achieved with trim level of 90 vs 99.
Output was fed to A90 headphone amplifier driving my random IEM.
I start listening to white noise. Instant distinction between the two inputs! I am talking not even trying hard! It is day and night.
I change to 1 kHz tone. Same except that now I can tell what is going on: one input, the one with 99 trim, is louder than the other! Repeat blind. Same clear results. Again, there is no effort here. They simply are not level matched.
I try many different methods to measure the output of the AVA from AP to digital voltmeter. They all show that fraction of dB difference. No way am I hear that slight difference so clearly.
Take a break. Have dinner. Pontificate. Come back to the bench and it hit me: is it possible the output impedance of AVA is changing with trim level? If so, it would not impact AP with its default 100 K Ohm impedance (ditto with DMM with 1M+). I drop down the impedance to 600 ohm and bam! The outputs no longer match!
Time to suffer through measuring amp output impedance with AP. The stupid thing doesn't have a measurement for this and the kludgy external app they had is now broken.
No matter, measure loaded and unloaded for each trim level: 90 vs max of 99. Ask ChatGPT to plot and compare:
Wow! Not only is the output impedance variable with trim, it is also variable with frequency. Perils of using "passive" level matching.
The A90 has an input impedance of 10K Ohm so we are talking big time interaction between the two.
To get around that, I matched levels using the output of the A90 headphone amp and this resulted in trim level of 96 (instead of 90) which audibly was very close. I need to go back and listen to the noise to see if the high frequency impact is gone.
I went back to Josh's protocol for level matching:
"Now it’s time to level-match. After consulting with several experts, I settled on a three-stage process. First, I played test signals — a 1 kHz sine wave and broadband CTA-2034 pink noise — and measured the Comparator’s RCA outputs with a digital multimeter.
Next, I moved the measurement downstream to the point of listening. I connected the Comparator’s RCA outputs to the RCA inputs of the Benchmark HPA4 headphone amp I’d use for testing, fed the amp’s headphone output into my E1DA Cosmos ADC, and rechecked each DAC’s level in REW using the same signals. Matching through the actual amp, rather than at the Comparator alone, ensured the levels were equal at the output I’d be hearing."
The voltmeter has an input impedance > 1 Megaohm which would result in similar error to what I observed making that measurement useless.
But he does go on to say he repeated the testing with the output of Benchmark LA4. I am wondering why he did not comment that the levels did not match. 50K Ohm is higher than 10K of my A90 but still, there should have been a mismatch. One would think he would have noted that instead of implying that the two protocols matched each other.
Regardless, even if he matched levels, he couldn't do so variably across the full frequency band. The above roll off may not seem much but it is combining with the same in the DAC. Here is that measurement:
Nearly 0.2 dB difference due to filter differences as measured at the output of AVA (NOT headphone amp).
The AVA is just a broken design for comparing sources. You can't have this kind of high, variable and frequency dependence output impedance in a comparator. Level matching is critical for proper AB testing. For speaker output, I am assuming there is an internal buffer so sidesteps this issue. But not for source/DAC testing.
As to applicability to Josh's testing, I am not reading that he was aware of this admittedly technical issue. But then again, he should have observed it when he tested at the output of the AVA and then output of the headphone amp. The two should have disagreed, making him ponder why.
But even if he had attempted to match levels, I am not sure he could across the full frequency band given the roll off in the DAC combined with variability of output impedance with trim level.
It ultimately goes down to a non-technical tester trusting the label on the box and not first verifying that it is a transparent switcher and trim control. My sense is that this comparator was designed for non-critical, gross level impairment in amps and speakers. And not all for comparing sources at all even though it seems to have that connection.
This. Is. Awesome. Great job of debugging!
Any purely passive attenuator will exhibit frequency response variations with level since the effective impedance changes with the position of the control. It also depends upon the source and load, natch. I did delve into this a bit a while back:
The plots showing frequency response differences is a post or three down from the first.
The ABX was hard for me -- I only hear up to 13KHz. Still I thought I was hearing a difference. And midway through I felt like I was losing the ability to tell the difference, just as shown in the results. I can't imagine I would have any chance at all to tell the difference with music instead of white noise. But with these white noise files I expect someone who can hear higher frequencies could easily get 16/16.
foo_abx 2.0.6d report
foobar2000 v1.6.6
2026-10-05 09:58:31
File A: Lwhite.wav
SHA1: ae7f9725e87abb47f717b63b49dedd3a9b838416
File B: Rwhite.wav
SHA1: 23f9d0e148b4fd7436d713fea21ecbf1da5d86d2
Output:
Default : Primary Sound Driver
Crossfading: NO
09:58:31 : Test started.
09:58:44 : 01/01
09:58:54 : 02/02
09:59:08 : 03/03
09:59:19 : 03/04
09:59:37 : 04/05
09:59:56 : 05/06
10:00:10 : 06/07
10:00:29 : 07/08
10:00:41 : 07/09
10:00:59 : 08/10
10:01:10 : 08/11
10:01:26 : 08/12
10:01:34 : 09/13
10:02:06 : 10/14
10:02:21 : 11/15
10:02:32 : 12/16
10:02:32 : Test finished.
Total: 12/16
p-value: 0.0384 (3.84%)
-- signature --
133112a448fe80cb7e8b61e1376ec2484ab96a3b
Great find! Finally, a very satisfying hypothesis for how he could have scored so high.
But he does go on to say he repeated the testing with the output of Benchmark LA4. I am wondering why he did not comment that the levels did not match. ...
Agreed. A thorough tester would have at least noted the difference. Saying nothing suggests agreement. Hard to imagine how this was missed.
The mistakes may have been innocent, but resistance to having others find them was not.
True. Especially with controversial results like this, independent review is so important, and could have happened a lot sooner with more cooperation up front.
However, he did eventually agree to sell the box.
I don't believe Josh would have let this box out of his hands for any price if he knew it was this broken.
foobar2000 v1.6.6
2026-10-05 09:58:31
File A: Lwhite.wav
File B: Rwhite.wav
Output:
Crossfading: NO
09:58:44 : 01/01
09:58:54 : 02/02
09:59:08 : 03/03
09:59:19 : 03/04
09:59:37 : 04/05
09:59:56 : 05/06
10:00:10 : 06/07
10:00:29 : 07/08
10:00:41 : 07/09
10:00:59 : 08/10
10:01:10 : 08/11
10:01:26 : 08/12
10:01:34 : 09/13
10:02:06 : 10/14
10:02:21 : 11/15
10:02:32 : 12/16
Total: 12/16
-- signature --
Thank you for trying the test. I agree that it is doable. And that younger guys may easily get 16/16. As we know, white noise analyzed on a constant-percentage bandwidth or octave scale shows an energy increase of +3 dB per octave as frequency rises. Thus it is very sensitive to FR decay at high frequencies. We have hard data that show that an abx comparator with such behaviour cannot be used for serious listening tests.
Based on Amir's discovery about impedance and the relays, I do think we have easier explanations for the results than hearing the unhearable and unmeasurable. Doing this kind of test seems really difficult though.
All the drama aside, Josh put as much work into this test as I've seen outside of actual scientific studies. And it still wasn't bulletproof.
It is a pleasure to come across such a fascinating story right after signing up. I realized something a long time ago: even if "golden ears"—people with ageless, superhuman hearing—truly exist, what does that matter to me? I cannot hear the subtle nuances they describe, so how does their painstaking commentary help me? Take headphones, for instance; the way they are worn affects sound performance. Consequently, "golden-eared" individuals with different head and ear shapes will inevitably reach different conclusions when listening to the same pair of headphones—and let’s not forget, they possess those miraculous ears. So, for the average consumer who trusts these experts, are we supposed to undergo plastic surgery just to use a pair of headphones? Finally, people often advise you to audition headphones before buying. Yet, even in China—where e-commerce logistics are highly advanced—most brands do not accept returns once the packaging has been opened. This forces consumers to visit physical stores to try out products, but such stores are rare, even in major cities, making the process difficult. While it is easy to find online reviews and recommendations for any given pair of headphones, the one thing missing is our own personal experience—unless, of course, we actually spend the money to buy them. I would also like to point out that Edifier and HiFiMAN are both publicly listed companies in China that regularly publish financial reports. Anyone can use tools like ChatGPT to gain a fresh perspective on the Hi-Fi industry through a financial lens. I believe this is a worthwhile exercise; after all, HiFiMAN’s gross profit margin rivals that of Nvidia.
