OK, we have some major discovery.
I set up Topping D70s and Matrix DAC using the same S/PDIF input coming from my Audio Precision Analyzer S/PDIF output. Hooked up the DACs to inputs A & B of the comparator and measure the output voltage. They were different. I used the trim control on AVA to get them to match to about 0.07 dB which was achieved with trim level of 90 vs 99.
Output was fed to A90 headphone amplifier driving my random IEM.
I start listening to white noise. Instant distinction between the two inputs! I am talking not even trying hard! It is day and night.
I change to 1 kHz tone. Same except that now I can tell what is going on: one input,
the one with 99 trim, is louder than the other! Repeat blind. Same clear results. Again, there is no effort here. They simply are not level matched.
I try many different methods to measure the output of the AVA from AP to digital voltmeter. They all show that fraction of dB difference. No way am I hear that slight difference so clearly.
Take a break. Have dinner. Pontificate. Come back to the bench and it hit me: is it possible the output impedance of AVA is changing with trim level? If so, it would not impact AP with its default 100 K Ohm impedance (ditto with DMM with 1M+). I drop down the impedance to 600 ohm and bam! The outputs no longer match!
Time to suffer through measuring amp output impedance with AP. The stupid thing doesn't have a measurement for this and the kludgy external app they had is now broken.
No matter, measure loaded and unloaded for each trim level: 90 vs max of 99. Ask ChatGPT to plot and compare:
Wow! Not only is the output impedance variable with trim, it is also variable with frequency. Perils of using "passive" level matching.
The A90 has an input impedance of 10K Ohm so we are talking big time interaction between the two.
To get around that, I matched levels using the output of the A90 headphone amp and this resulted in trim level of 96 (instead of 90) which audibly was very close. I need to go back and listen to the noise to see if the high frequency impact is gone.
I went back to Josh's protocol for level matching:
"Now it’s time to level-match. After consulting with several experts, I settled on a three-stage process. First, I played test signals — a 1 kHz sine wave and broadband CTA-2034 pink noise — and measured the Comparator’s RCA outputs with a digital multimeter.
Next, I moved the measurement downstream to the point of listening. I connected the Comparator’s RCA outputs to the RCA inputs of the Benchmark HPA4 headphone amp I’d use for testing, fed the amp’s headphone output into my E1DA Cosmos ADC, and rechecked each DAC’s level in REW using the same signals. Matching through the actual amp, rather than at the Comparator alone, ensured the levels were equal at the output I’d be hearing."
The voltmeter has an input impedance > 1 Megaohm which would result in similar error to what I observed making that measurement useless.
But he does go on to say he repeated the testing with the output of Benchmark LA4. I am wondering why he did not comment that the levels did not match. 50K Ohm is higher than 10K of my A90 but still, there should have been a mismatch. One would think he would have noted that instead of implying that the two protocols matched each other.
Regardless, even if he matched levels, he couldn't do so variably across the full frequency band. The above roll off may not seem much but it is combining with the same in the DAC. Here is that measurement:
Nearly 0.2 dB difference due to filter differences as measured at the output of AVA (NOT headphone amp).
The AVA is just a broken design for comparing sources. You can't have this kind of high, variable and frequency dependence output impedance in a comparator. Level matching is critical for proper AB testing. For speaker output, I am assuming there is an internal buffer so sidesteps this issue. But not for source/DAC testing.
As to applicability to Josh's testing, I am not reading that he was aware of this admittedly technical issue. But then again, he should have observed it when he tested at the output of the AVA and then output of the headphone amp. The two should have disagreed, making him ponder why.
But even if he had attempted to match levels, I am not sure he could across the full frequency band given the roll off in the DAC combined with variability of output impedance with trim level.
It ultimately goes down to a non-technical tester trusting the label on the box and not first verifying that it is a transparent switcher and trim control. My sense is that this comparator was designed for non-critical, gross level impairment in amps and speakers. And not all for comparing sources at all even though it seems to have that connection.
