Audio by Van Alstine ABX Comparator Review
Is there a comparator for ABX testing of ABX Comparators?
Yes
:cool:
It won’t fix the lack of scientific discipline in Josh’ test though.
Reactions: gvl
Was Josh using headphones or loudspeakers?
IEM:
For all tests, I held the amp and IEM constant: the Benchmark HPA4 and the Moondrop S8. I chose the HPA4 for its low distortion and the S8 because it’s a well-regarded, neutral-leaning reference IEM with a mainstream tuning — resolving enough to expose any differences and neutral enough not to color the comparison.
Do HiFi IEMs not block the ambient room sound? My only experience with them was years ago when playing in a band, and I couldn't hear much of anything unless it was in my monitor mix. I'm wondering how he could hear relay clicks with the monitors in his ears.
According to someone else who reported back from the A/S thread, he says he couldn’t hear the clicks (well or at all I’m not sure) with the music and IEMS. As well, apparently there’s significant electronic noise audible through the drivers when switching. No word on whether that noise has a different signature for energized vs deenergized states.
So many people still asking so many questions... which may provide more background IF the original perpetrators of this entire thread still showed signs of life, but we hope they got their $3k party and are fine.
I hope we can universally agree that... THERE WAS NEVER A VALID ABX TEST TO BEGIN WITH AND ZERO HAS BEEN PROVEN IN ANYONE'S ABILITY TO HEAR DIFFERENCES BETWEEN VERY SIMILARLY MEASURING DACS.
This whole thread is moot now. Nothing else is needed to prove the original premise of the "test" as garbage as the box.
They reduce it by 20-30dB. Not blocked.
Try listening to relays while wearing IEMs. I can hear the relays in my analyzer wearing IEM if it is sitting on my desk less than a meter from me. YMMV, but remember the guys on AS all have superhuman hearing so 30 dB of attenuation is no big deal. ;)
And just saying IEM says little. How good is the fit of the ear tips? Which material? etc etc.
Objective measurements aren't very revealing for this class of device. You need to do a blind test with another comparator.
If this is sarcasm it is utterly enjoyable. :-)
  • a-surreal-infinity-mirror-effect-showing-a-repeating-image-of-a-glass-of-cold-water-with-ice-c...jpg
Sorry, I gotta jump in on this for a sec…
* sidenote for anybody watching this thread and wants to know the single best way to improve your stereo system: close your eyes.
I agreed that certainly a way to change perception. I often close my eyes when I’m listening to loudspeakers either it shows or when I’m auditioning them and sometimes at home. It can really change the experience.
I’ve always loved playing with perception, and I used to listen to my system fairly often with the lights out, or in my newer room I can turn the spotlights completely off over the speakers and the wall behind them but have soft light over my listening sofa, so I’m just peering into a big area of darkness and it can make sound staging and imaging and the sense of acoustics within that space quite vivid.
Though more recently in the past years, I’ve come to enjoy even more playing some soft coloured lights, often slowly modulating, on my projection screen behind my speakers and with the lights off in the room.
I find the colours on the screen perceptively add more “ colour” to my perception of the sound in a way I really like.
Example :
Now… back to crappy ABX boxes….
So, these are not the droids you'e looking for.
The reactions at AS are as to be expected. A hit dog hollers.
You want the sound of a $50k DAC but can't afford the one made by Patek Philippe? No problem. Get a $200 DAC that tests well and apply the right filter.
Before you do that you’d need to measure the $50k DAC to find the right filter. In most cases I’d bet that there is no “right” filter. The $50k DAC probably measures audibly identically to the $200 DAC and its “sound” has zero to do with anything other than sighted bias.
Hmm, so it's still not clear to me how Josh could have gotten almost all of the comparisons correct. 20-30 dB seems like a lot of attenuation to discern one click from another especially if any music was playing, and it seems like Amir's tests show that the ABX box introduced enough distortion that even if the DACs did have an audible difference it would have been masked. So he couldn't have heard sample differences, and if he also couldn't hear the clicks well, then either there was some other tell that is still unknown or it was all fabricated. I hate to believe that anyone would do such a thing though, so I was hoping for an obvious tell that he may have unknowingly locked onto.
It’s only clear to Josh.
I have no idea if he was listening for the sound of the clicks, during quiet passages or even without the music playing. If so, intentionally or accidentally.
I don’t understand most of his actions or inactions. There are so many. It does show how hard it is to do a proper unbiased study when you don’t have your shit together. By incompetence or by deception. Either way his little excursion with this poorly designed box is so sloppy the results are unbelievable.
I don't understand why the main switching circuitry in this box needs to be active, aside from the DC voltages needed to switch the relays and any possible remote-control receiver circuitry. It's supposed to be a pass-through box, a straight wire with zero gain. Any gain adjustments would be done upstream by the AB sources. A passive box would provide much better specs, imho.
A passive approach is possible but it has its own problems. First of all many devices have fixed outputs, so you can't gain-match upstream without adding a preamp or similar, in which case what device are you testing? If the gain is set passively then you're talking about a passive attenuator, in which case now you're varying the input and output impedance. And then you have the question of DC offset, which is the most obvious 'tell'.
The reality is active electronics, thanks to negative feedback, are not the limiting factor in distortion and noise performance at line level, and they solve for many other problems at the same time.
Unless the trial is blinded to both listener and the person conducting the experiment, then the results are dubious. I know that many of you think that's too high a bar, but that's the way it has to be. I'm fine if, as an individual, you convince yourself doing this, but the results can be influenced by too many biases to be considered meaningful.
Again, it's really hard to do this right. And it wasn't done right in this case.
Amen.
About 30 years ago I also played around with lighting and regularly had listeners over (in the evening mostly) and sometimes experimented on them without them knowing.
I noticed that when I had full lighting on (and had fluorescent 'cool' lighting on the curtains) that people found the sound 'analytic' and 'cold'.
Whenever I had dimmed 'warm' light people found the sound 'warm' and 'lush'.
So yes, completely dark, mood lighting all changes a sound experience.
On top of that I also found that later in the evening my hearing got noticeable 'better' than during a day... and no this wasn't caused by mains 'pollution' as some folks tend to shout. What I noticed is that one listens at lower volume and for instance later at night I could hear a clock tick during quiet passages and not during the day.
I also found that when listening to the same song, same gear but with a few days between them it could sound 'better' on one day than another.
My conclusion was that the brain (hearing) is a funny thing and influenced by factors other than just hearing...
Maybe not even that if the test results were not intentional.
Fact is we can only guess how the 'unexpected' result came to be.
I don't think the filters in a DAC would actually have mattered (unless there is an audible ripple like in the, not used, D10 ...perhaps) as all comparisons were done in 24/96 which moves the possibly problematic reconstruction filter differences up to around 45kHz.
We will never know because no recordings of the test signal were made.
This is what Josh posted about the relay sound:
A small, uniform click sounds with every button press, concealing whether an actual switch has occurred.
Erin also did not notice a distinct sound but this is diametric to what Amir reported. Now... relays DO have a different 'click' when making and breaking contact (energizing or de-energizing) but this would only be apparent if one actually used relays a lot and knows how they do sound. If not chances are one would simply hear a 'click' and not think about that... Possibly, when they were actually heard while looking for audible differences during a switching one could perhaps pick up on this.
Again... we do not know if this was the case or not. speculation.
So click sound, imperfect level matching, roll-off caused by filter settings, increased distortion (that would be the same for A and B), 0.2dB difference max. at 20kHz, somehow having very good hearing capabilities, doctoring of actual results, valid test after all ... we can only speculate and do/did exactly that before and after this short measurement of the ABX box.
In the end ... Josh's 'results' are not as expected by many here at ASR and as expected (confirming) to others. Seems the case with just about any subject in life.
Sadly we will never know with 100% certainty and have to find peace in that. Why ? because Josh needs to be involved and 'tested' which we all know will not happen.
