I have used it for amplifiers mainly. Anyone who has tried knows that ABX testing with speakers is pointless unless you can put them in the exact same spot. Which is why the Harman research used the speaker shuffler.
Moving on…
I’ve never noticed the difference in the relays as a factor in my listening. Frankly, I’d never considered the relays could sound different so it was never something in the back of my brain. **edit: I do believe that I recall hearing a difference, but I never attributed it to a specific A or B output. And when you switch back-and-forth, you lose track of which one is which very fast.**
Now, with this knowledge, I suppose if I looked at the test screen while intently listening for which sound correlated to A or B then it’s possible I’d have the ability to cheat the testing. And I understand there’s the possibility that subconsciously influencing my results.
However, keep in mind that I’ve always provided FR results with the DUT and speaker load attached. The differences heard were always singled out to response deviations. I’ve also *not* heard differences in other comparison tests. These deviations - or lack thereof - tracked when using static and reactive loads in my bench testing. IOW, the data backed up the hearing results in these “pretty obvious” cases. Example at bottom.
So, while the results here look pretty damn bad, I’m not ready to throw mine away. It would certainly be an issue if the goal is to compare “ultra clean, high resolution” devices against lower quality components - where the best would be relegated to “sucky”. Otherwise, I’m not seeing why everyone is ready to set this thing on fire or if it’s more of a response to Josh’s testing and the goal to debunk his results. My gut still tells me that there is a better explanation to his success rate on items that should sound extremely similar but it’s possible the ABX is not the ideal device for this test, too.
I will still use the device as it’s proven great for sanity checks. And I await the better solution from Matt.
And if there’s interest here I’ll grab a recording from my phone at my listening position of the relays as I switch outputs and upload it to my YT channel (not shared publicly because it’s just a video of some relays without context).
Erin
Example of FR directly out of amp/speaker load that was audible (99 vs 92 in ABX volume adjustment). Screenshot from my review of McIntosh MC275 mkVI vs Orsefon MC275 (McIntosh “clone”).
And then bench testing with my complex load
