Audio by Van Alstine ABX Comparator Review
Most soundstage differences are FR differences, especially depth-axis changes like he reported, where high-frequency roll-off can make some of the content sound pulled back and this can feed into an interpretation of "more stage depth", with the flatter FR conversely sounding closer to you and also "flatter" depth-wise (fewer objects appearing pulled back).
I also put the unit in its ABX mode. Boy, it does a lot less than I thought. You run the test. But then it is your responsibility to record your selection, and then to turn on the switcher LEDs and walk through to see which ones you got right! In other words, there is no score keeping at all. I could very well note a trial wrong during blind and/or then reveal cycle or make up the entire results!
I thought it would have a voting button for each trial that it would then report the results at the end. But there isn't. In this regard, there is no way to show evidence that you passed a test. Hence, it is just for one's personal satisfaction than proving an outcome externally. You are completely at the mercy of the person reporting the results as to accuracy and honesty.
Unless the trial is blinded to both listener and the person conducting the experiment, then the results are dubious. I know that many of you think that's too high a bar, but that's the way it has to be. I'm fine if, as an individual, you convince yourself doing this, but the results can be influenced by too many biases to be considered meaningful.
Again, it's really hard to do this right. And it wasn't done right in this case.
We have claims from Josh that what he heard was soundstage differences, not frequency response differences. Maybe he can't tell the difference but assuming he does, then frequency response variation doesn't explain his claims.
I take your point, but if I recall correctly he's written that he detected subtle differences in the shallowness/depth of the perceived soundstage (as opposed to, say, the width or height). To me that is consistent with what he's also written about focusing in on and hearing slight differences in the decay of certain instruments/notes/sounds.
Of course this is also irreducibly speculative to a point since we're trying to translate someone else's subjective perceptions, but to me Josh's stated impressions seem like things that very much could be impacted by small changes in frequency response and distortion, as both factors can impact the perception of "ambience and air," which I think it's reasonable to say are likely factors in someone's perception of soundstage depth. EDIT: I see that @donjoe0 posted the same idea as I was typing this (and more concisely than I have expressed it, and with the key added factor of phase )
To be clear, I'm not trying to put forth an argument that claims Josh heard exactly what he says he heard - I of course don't know that one way or the other, and it very well could simply be unconscious bias from the relay-sound difference.
Instead, my point here is simply that his claims about what differences he heard could potentially be connected to the nonlinearities you measured in the ABX box. They might not be connected to that, but I don't think we can rule it out, as there is in my view a plausible connection. If Occam's Razor points to the relays, I have no interest in arguing against that. I'm just saying we don't really know.
I'm sure he did, but why he heard it, as ever, is an open question until we can find hard evidence to corroborate the heard differences.
Agree - I should have been clearer. I was thinking of a scenario where the reverb tails and such might actually have been reproduces slightly differently versus a scenario where the unconscious "tell" of the relays manifested as a perception of increased or decreased reverb tails when no such difference actually existed. But it's probably a distinction without a difference, so in the end you're right.
It's on @NTTY hands now to hook couple of DACs to it (preferably of the shorts of the original test, which if I'm right included one with low impedance input, the trick to gain couple of dBs less noise) and put the FR deviations to rest if there's zero difference.
The rest of the performance we already know by this review.
Have JNF levels under 0.4dB@20KHz been demonstrated?
By the way, there's also this result that popped up while I wasn't reading the forum for a few months: https://www.audiosciencereview.com/...gs-we-can’t-even-measure-”.72288/post-2658443
(I assume you mean JND, I've never heard of JNF.)
As I've noted before, I'm not sure JNDs are directly translatable to Just-Noticeable Coloration values (for JNDs you amplify or attenuate the whole spectrum equally, it's not about tilting its envelope so some frequencies are affected more than others), but the 1988 Toole & Olive study seems to suggest they do hit about the same order of magnitude, as they were actually looking at colorations in that study and they found the best-case listeners able to detect colorations/resonances about -40 dB below the signal (so like +0.086 dB in the summing result, if correlated, less if not-quite correlated).
Easiest ABX I ever did. Which I suppose is @pma's point.
See attachment.
Thanks @RandomEar! Interesting paper. Not sure it speaks directly to the matter at hand since specific frequencies were not tested. But I learned something regardless, and interesting to see how discriminating people can be with white noise.
At any rate, I think it's vanishingly unlikely that Josh can hear 20KHz anyway, so we are probably looking at the delta at around 15KHz? Which would be ~.05dB or so? Just guestimating and eyeballing the graph, hardly scientific. Still, my intuition is that the FR change is not it.
Indeed. Anyone can hear a difference in mechanical sound of energized and de-energized relay.
As almost always, it is not trivial like that. In fact we still know a little about the VA box, even if what we know shows it is a piece of s..t.
Starting with 5 As in a row threw me for a sec, though
At volume 90, it is down 0.1 dB at 9.5 kHz and 0.2 dB at 13.6 kHz (compared to 0.1 dB @ 15.1 / 0.2 dB @ 21.4 kHz for vol. 99). But Josh didn't need to use attenuation for all DAC pairs and I think he didn't even need to go down to 90 for any of them.
Unfortunately, Erin has used it for amplifier comparison, and on multiple occasions.
I have used it for amplifiers mainly. Anyone who has tried knows that ABX testing with speakers is pointless unless you can put them in the exact same spot. Which is why the Harman research used the speaker shuffler.
Moving on…
I’ve never noticed the difference in the relays as a factor in my listening. Frankly, I’d never considered the relays could sound different so it was never something in the back of my brain. **edit: I do believe that I recall hearing a difference, but I never attributed it to a specific A or B output. And when you switch back-and-forth, you lose track of which one is which very fast.**
Now, with this knowledge, I suppose if I looked at the test screen while intently listening for which sound correlated to A or B then it’s possible I’d have the ability to cheat the testing. And I understand there’s the possibility that subconsciously influencing my results.
However, keep in mind that I’ve always provided FR results with the DUT and speaker load attached. The differences heard were always singled out to response deviations. I’ve also *not* heard differences in other comparison tests. These deviations - or lack thereof - tracked when using static and reactive loads in my bench testing. IOW, the data backed up the hearing results in these “pretty obvious” cases. Example at bottom.
So, while the results here look pretty damn bad, I’m not ready to throw mine away. It would certainly be an issue if the goal is to compare “ultra clean, high resolution” devices against lower quality components - where the best would be relegated to “sucky”. Otherwise, I’m not seeing why everyone is ready to set this thing on fire or if it’s more of a response to Josh’s testing and the goal to debunk his results. My gut still tells me that there is a better explanation to his success rate on items that should sound extremely similar but it’s possible the ABX is not the ideal device for this test, too.
I will still use the device as it’s proven great for sanity checks. And I await the better solution from Matt.
And if there’s interest here I’ll grab a recording from my phone at my listening position of the relays as I switch outputs and upload it to my YT channel (not shared publicly because it’s just a video of some relays without context).
Erin
Example of FR directly out of amp/speaker load that was audible (99 vs 92 in ABX volume adjustment). Screenshot from my review of McIntosh MC275 mkVI vs Orsefon MC275 (McIntosh “clone”).
And then bench testing with my complex load
Several of those DACs were thoroughly tested, and that data show that any FR differences are too small to be significant. I disagree vehemently that Josh has such superhuman hearing. Especially given the fact the box has been revealed to be garbage.
Okay, but I’d like to clarify that even if there were tiny FR differences, they could be from the ABX box’s high-frequency droop that varies by volume level (and possibly by impedance). I’m not disagreeing with you, but I’m also not prepared to simply assume he must be lying.
Those numbers appear to be down from 0dBFS. The number I was eyeballing was the difference between the drop at full volume at 15KHz and the drop at 90 at 15KHz.
Sorry, I just edited that right when you posted. The numbers are compared to full volume (99). It's extracted data so not eyeballed but I used the plot images to extract it, not Amir's numerical data (which I don't have).
EDIT: My wording was misleading. The numbers are compared to the mean level between 50 and 1000 Hz at each attenuation. So it is not each compared to the full volume level of 99. The original post explained it correctly.
Yep.
That 0.1dB or whatever difference may occur is the reason that the initial level must be absolutely matched .
Arguing about level difference and how small it may be throws out the whole proper ABX principle, as we already know by the studies that level is the greatest tell along with FR.
Thanks, Erin! That's very helpful context.
Wherever we land on this, we ought to treat this statement with a similar level of acceptance or skepticism as we treat Josh's statement that the clicks sounded uniform to him. The main difference is that we like Erin and we "don't like" Josh. I suppose because Erin has not made an extraordinary claim, we don't need to subject his statements to extraordinary scrutiny. But at the very least, Erin's statement supports the idea that Josh's saying the clicks sounded uniform to him is not entirely risible.
Both can be true.
I for one would really appreciate that! And also, if it's not too much to ask, maybe a measurement of SPL for the relay click? Doing PMA's test, it occurred to me that I had no idea what level I should be playing the files back at.
