AudioStudies
- Joined
- May 3, 2020
- Messages
- 717
- Likes
- 387
Audio Bit Rates
Audio Bit Rates and Uncompressed Files
Every second in an audio recording has a specific quantity of bits. When considering various types of sound files this is expressed as the number of kilobits of data per second (kbps). For example, a 128 kbps file has 128 kilobits stored for every second of audio. This is an example of an audio bitrate that defines the amount of data that is stored in the sound file.
Every audio file has an associated bitrate. Faster bitrates correspond to more data stored across the full frequency range. The more kilobytes that are stored per second the greater the potential for better sound quality of the file, within the limits of human hearing, for similar types of files. Uncompressed audio files include the following types:
- Compact discs (CDs) have a bitrate of 1,411 kbps at a 16-bit bit depth. This was first established by Philips and Sony in 1980; and adopted as a standard in 1987.
- WAV files were developed by Microsoft and IBM to enable computers to read pulse code modulation (PCM) data. High-quality WAV files have a bitrate exactly the same as CDs at 1,411 kbps at 16 bit. However there are variations of WAV files. The actual bitrate is determined by a specific formula which multiplies the sampling rate with the bit depth and the number of channels.
- AIFF files, were developed by Apple, using the same uncompressed technology as WAV files. Much like WAV files AIFF files are another way for electronic devices to read PCM data.
When it comes to audio and bitrates, size does matter. The more kilobits per second the greater the quality of the sound. For many casual listeners, a bitrate of 320 kbps is acceptable. Clearly, CD-quality audio with 1,411kbps will sound better, particularly to discerning listeners.
PCM (pulse code modulation) is the hierarchical format for uncompressed audio. All recordings initiate as soundwaves in an analog setting. PCM converts this information into digital format by sampling recordings.
Compressed Audio Files
MP3s are a very common form of a compressed audio file, with a maximum bitrate of 320 kbps at 16 bits, substantially lower than that of the uncompressed formats. MP3s use a compression codec that removes frequencies while trying to preserve as much of the original recording as possible. This allows for reduced file sizes but sacrifices sound quality. MP3s are an example of lossy compression, because the compression scheme does not include all of the original information in the recording.
MP3s were very popular in the early days of the internet due to the small file size; enabling easier sharing across a then slower internet. MP3s are still used heavily by streaming services and digital music platforms making them one of the largest formats for DJ music.
Free Lossless Audio Codec (FLAC) is an open source compression method for audio files; with significant advantages over MP3 because original recording is unaffected by the compression (no information is subtracted). With FLAC the file size can be reduced up to 60% compared to the original uncompressed file (such as WAV).
FLAC has grown in popularity, in large part to the lack of licensing restrictions, and has become the primary way to offer compressed lossless audio. FLAC also offers extra metadata to be stored like album art which WAV files do not support.
Lossless Audio Formats
The following table depicts the more common lossless audio formats with the most relevant information:
Format Sample Rate Bitrate Type Open Source? Metadata?
WAV | 44.1 kHz (usually) | 1,411 kbps (usually) | Lossless | No | No |
AIFF | 44.1 kHz (usually) | 1,411 kbps (usually) | Lossless | No | Yes |
FLAC | Up to 655,350 Hz | 1,411 kbps (usually) | Lossless | Yes | Yes |
ALAC | Up to 384,000 Hz | 1,411 kbps (usually) | Lossless | Yes | Limited to ITunes |
WMA | Up tp 96 kHz | Up to 768 kbps | Lossless | No | Yes |
Although FLAC has some advantages over WAV, WAV is found in many pro audio devices that are not capable of FLAC. Clearly, lossless is preferable unless file storage capacity is of concern, or lossless isn’t available for some venue. For example, most of the internet radio stations broadcast in a lossy format.
Lossy Audio Formats
The following table depicts the more common lossy audio formats with the most relevant information:
AAC | Up to 96 kHz | Up to 529 kbps | Lossy | No | Yes |
OGG | Up to 192 kHz | Up to 500 kbps | Lossy | Yes | Yes |
MP3 | Up to 48 kHz | Up to 320 kbps | Lossy | Yes | Yes |
AAC is capable of the highest bitrate of the lossy formats but is not open source.
