Hi to everyone!
I recently bought an Audient ID48.
I found that in some conditions, the outputs will distort/clip on initial transient.
DAC outputs should have CS43198 despite Audient says “Sabre” on his site.
I’ve conducted some measurements and attached there.
I reproduced this issue in this way:
Ableton Live
Open a MIDI Channel with a good low frequency sine wave with VST (Serum 2 used here)
Attack Parameter relatively fast and sine wave phase starting from triggering.
Filter it with a steep low pass filter to clearly leave only the sine wave.
Do some fast triggering and you will find the distortion on triggering only.
Other method:
I’ve downloaded a high quality 36Hz sine wave with phase starting at 0deg.
Do some fade at both starting and ending.
Filter it same as before.
Distortion only on fade portion.
Ableton Live
Other method:
