Audient ID4 MKII with planar like Hifiman HE400SE?
declider
Hi! First of all, I’m glad to leave my first message here! I’ve been reading this forum for a while now.
And I have a nooby question because there’s just too much new info for me:
I have an Audient ID4 MKII audio interface. It’s all good, except the headphone output has a high impedance (22 Ω), but I didn’t know about that because all I’ve heard were praises about its headphone output.
And i want to buy Hifiman HE400SE planar headphones, which I recently learned more about.
Here’s where my confusion starts and what I’ve read online:
  • "HE400SE is planar, and even with its low impedance, it’s really hard to drive to its full potential."
  • "Audient is strong and can drive headphones up to 600 Ω."
  • "Audient ID4 MKII has a 22 Ω headphone output; it’s very bad for low-impedance headphones."
  • "Planar headphones, especially Hifiman HE400SE, have an almost flat impedance frequency response, so high-impedance headphone outputs are not that bad."
  • "Planar headphones still won’t reach their full potential; they are REALLY hard to drive because they are planars with low sensitivity. Buy 150+ Ω headphones."
  • "Their sensitivity isn’t THAT bad, and Audient is strong, so no problem—just look how good it sounds in Julian Krause’s video."
  • "Yeah, but with such a low impedance difference, bass damping will still be high, and planars will never sound full even if they’re loud. Impedance always matters; buy an external amp."
After reading all of that, I feel lost. Of course, these are probably just opinions—some right, some wrong—but I’ve never had experience with anything like this, so I can’t tell for sure, is the Audient ID4 MKII without an external amp is at least enough good for any planar headphones like Hifiman HE400SE?
Some specs:
Hifiman HE400SE (and review):
- Impedance: 25Ω (or 32Ω?),
- Sensitivity: 91dB
Audient ID4 MKII (and review):
LINEUP:18dBu = 0dBFS
THD+N @ -1dBFS:0.0009%
DYNAMIC RANGE:125.5dB A-Weighted
CROSSTALK:>116dB
FREQUENCY RESPONSE:±0.1dB 10Hz to 40kHz
MAXIMUM LEVEL @ 30R:2.59V Peak, 1.827V RMS, 223mW
MAXIMUM LEVEL @ 62R:4.18V Peak, 2.95V RMS, 280mW
MAXIMUM LEVEL @ 600R:7.72V Peak, 5.46V RMS, 100mW
1/4” TRS JACK:Tip (Left), Ring (Right) & Sleeve (Shield)
Impedance22Ohms
So, since you say you have both, do the cans go plenty loud enough in this combination without any obvious distortion? Should be fine then.
I mean, it's not an ideal combo... I can't imagine that those 22 ohm series resistors are all that large. Maybe 1/4 W tops, if that. In practice, the crest factor of actual music is going to keep average power down and thus likely make this a non-issue anyway.
