A lot of misunderstanding here - as always.
Your test is an interesting one, as many of us have said, and I appreciate you creating the files and posting this.
And of course, you cannot explore S/N ratio without having a signal - no one disagrees with that, and contrary to your typically condescending and dismissive attitude, everyone understands that.
And at the same time, such a test is limited, for very good and well-understood reasons that have been noted repeatedly in this thread.
More precisely, since you hold yourself up as an experimental scientist with superior understanding to most other members here, there is nothing about your test that demonstrates with any scientific precision that equipment noise levels of -110dB (or whatever) are excessive, silly, or unnecessary.
To be clear, I am
not saying you are incorrect about this - I actually agree that comparing gear based on one having -110dB and the other having -140dB is indeed pointless for music listening purposes - both are functionally transparent when it comes to noise.
However, this is an opinion that is supported only in an informal and very limited way by your test - because -110dB is so far below -60 or -70dB that by common sense -110dB must be far more than we need. But your test does not allow us to draw any scientifically rigorous conclusions about this because we don't actually know what the level is when noise is truly, reliably inaudible. And we don't know that from your test because even if we use the 200Hz tone in your test files as our amplitude-reference signal for a SNR test, the fact remains that when we listen to music at the same volume as we will listen to this 200Hz tone, there are rests in music and there are silences between tracks. And so the experience of listening to the equipment during those moments of silence or near-silence in the source will be part of the same music listening experience as listening to that 200Hz tone.
This is just one reason (or aspect, or example, as one prefers) why your test is interesting and instructive, but does
not actually provide the kind of scientific proof of the sweeping claim you are making. This is exceedingly common with your posts: you provide a great practical test or set of measurements - and then you use them to grind your pre-existing axe and make dismissive comments about the entire orientation of this site and
@amirm's equipment tests, and in the process you make sweeping claims that exceed what your test or measurements can actually support.
And then when anyone points this out, you throw a little tantrum and say everyone else is too dumb to understand.
It's quite predictable, and rather tedious.
