Audibility thresholds of amp and DAC measurements
this mechanism does not explain the observed difference between them.
Are you still talking about your sighted listening observed differences here?
Yes, DeltaWave may be sensitive to low-frequency phase. But in this situation, the measured low-frequency frequency response and phase response of the two DACs, as recorded by the same ADC, are virtually identical; therefore, this mechanism does not explain the observed difference between them.
Meanwhile, after looking into the issue you raised, I found some very interesting details in my old measurements. The information needs to be clarified; I’ll write about it later.
True. At the same time note that the first pair of files is between the original track and just one DAC recording, so that one includes the AC coupling effect in the ADC.
Yes. And also some related questions.
Perhaps I didn't quite understand your point. The ADC is isolated, and there are no significant traces of mains voltage in the digitized signals.
Or maybe I misunderstood what you were discussing. I thought you were talking about the phase shift by the ADC input filter, not residual of mains frequencies.
That's right—the ADC or DAC filter.
If you emphasized that the same ADC was used for both files being compared, then that is indeed important. My ADC has a cutoff at 0.8 Hz, and this could make a difference when comparing the digitized file to the original.
Then we don't need any mechanisms, low frequency phase - or anything else to explain those observations, other than good old perceptive bias** which in absence of a well controlled blind test are overwhelmingly more likely to be the explanation, than any other "mechanism"
** that all humans are subject to - all the time (it is how our senses work), including me, everyone reading this thread, and even you.
Of course, you always have to look back, double-check, try to imagine the opposite scenario, and look for confirmation in your perceptions in order to at least somewhat rid yourself of bias... But I still choose to seek answers. Regardless of how significant the audible differences were, a serious difference in the sources was indeed found—and I haven’t even had a chance to describe it here yet.
Ah, but you accept that they are NOT identical.
Seriously, read the thread I linked to, about how miniscule differences near DC will have a big impact on nulling tests.
You may note that I keep insisting that the analysis of any difference measurement must include the normalized difference spectrum. This will disappear stuff like DC and VLF stuff from wind, etc, and their interaction with input and output capacitors. You'll be able to see that error, of course, in the error spectrum, but you'll also know the frequency content of the error.
So as long as SINAD is >= 85 and dynamic range >=96 the differences above this are inaudible and it realistically doesn’t matter?
As an absolute statement, not quite. Some people in some situations (Eg sound proof test room with headphones) can possibly detect lower levels - though probably only when AB switching. But almost certainly not sufficient to impact music enjoyment.
For almost everyone though in real world listening - the statement is effectively true.
But also bear in mind your statement doesn't cover frequency response variation. If a device has a non-flat frequency response that can be quite audible - again beyond a certain level.
Whether it matters is a personal question. It’s better to ask whether it’s possible to hear the differences. But even that depends on individual hearing.
SINAD is measured at 1 kHz. Distortion may be lowest at this frequency, but SINAD provides no information about the rest of the frequency range. Possible low-frequency distortions directly affect the audible range, while high-frequency distortions may affect it through nonlinearities. Also, you didn’t specify under what conditions the SINAD value was measured, and distortion can increase significantly under load. A great deal also depends on whether distortion or noise dominates the SINAD.
A DR of 96 dB is quite good when considering end-user listening conditions. However, if this refers, for example, to the DR of a USB dongle, you’ll need to subtract the volume control level and approximately -15 dB for the peak factor. Then it will become clear how much remains.
I believe that, overall, these two numbers aren’t enough to draw even a rough conclusion. I have a USB DAC on my desk with a SINAD of 108 dB, but its sound is simply awful. Though, of course, the issue isn’t the specific SINAD value itself. By the way, it’s also important to consider what the device with these technical specifications is intended for.
One striking thing, at least to me, is that all amps with SINAD >100 use a switching power supply.
There is also something going on with feedback and filtering.
In my mind, this, technically speaking, seems to produce superior measurements.
I do wonder if there is something lost somewhere?
Yes, I am a big fan of straight wire with gain, but sometimes I wonder.
That's not written in stone, this one for example uses linear:
(There's others as well, around -100dB THD+N if you search)
For class-D (and derivative) amps ... sure.
There are several technical options to skin a cat.
The power supply choice you mean ?
That is actually determined by cost, size and weight to power ratio.
Also a wide-range power supply is very handy as opposed to regular transformer.
In cheap class-D ... sure bandwidth is lost, FR flatness (load dependent peaking), (IM) distortion > several kHz but also heat production, weight, size, production costs, very likely longevity and serviceability.
Note the word 'cheap' which is the most important factor here.
The real question is how audible this all is.
