OK so to move forward with some further more scientific tests you will need some software to perform ABX testing. Copying some explantory text from elsewhere;
Here's how ABX testing works: The ABX box presents two audio signals, A and B, plus a third, X. X is either A or B; the assignment is random, and it changes (or doesn't change) with every trial. So you listen to A, listen to B, listen to X, and then decide whether X is A or B. Then you or the test administrator activates a function on the ABX box that displays whether X was A or B for each trial.
Random guessing will, after enough trials, result in correct selections 50 percent of the time. So, to prove there's a significant difference between A and B, you'd have to correctly identify X somewhere between 50 and 100 percent of the time. Even someone randomly guessing might get 6 or 7 out of 10 right, so the results aren't meaningful unless you can do even better than that. For a 95 percent confidence level (a typical standard for statistical significance), you'd have to have correct identifications on 23 out of 24 trials.
I will let the statisticians amongst you advise what is most appropriate, but the Foobar ABX software defaults to 16 trials not 24.
So download and install Foobar music player here:
https://www.foobar2000.org/getfile/c50260edf59e3e13d2cb66f34a9a8784/foobar2000_v1.6.2.exe
Also the ABX plugin:
https://www.foobar2000.org/components/view/foo_abx
just dbl click the plugin to install.
To use Foobar watch the following video. Set your sound device then load the 2 A/B sound files. Right click them and select ABX test.
The the order of track A and B always remain the same. You can play them as often as you like comparing them. Then play X / Y and decide if it it is A or B. Click your selction and press next trial.
Once finished you will end up with a result like this showing how many times you got it right.
Just copy and post here.
EDIT:
To increase reliability of the data you can set you playback volume levels to 80 to 85dB(A). You can get an idea of this by playing the "clean" audio file and measuring the sound level with a phone sound level meter app. Without calibration this wont be very accurate, but still it might help.
I use the app iNVH by Bosch. Its available on Android and IOS.
