AluminiumEar
- Joined
- May 14, 2021
- Messages
- 28
- Likes
- 116
The other one is Abyss... i guess?Audeze is one of only two companies providing headphones to me for testing.
Email their customer support and ask them to sell you their shorter leather band (or DIY). Once the top of the head does not touch the headband anymore, comfort improves a lot.
Again this should have been done factory default. What is the point of a suspension headband if the suspension is not working?
Anyway simple fix for an awesome headphone. I miss mine...
That was exactly my experience: original headband => carbon fiber with hot spot => carbon fiber with short leather strap.Thank you for your suggestions.
Actually I bought my LCD-XC quite some years ago, with the original, heavy headband, before the carbon headband.
With the original headband, the top of my head was really aching quickly.
So I bought the expensive and lighter carbon headband. The carbon headband solved the initial problem (pain at top of the head), allowing the headband to stay by putting instead a lot of pressure around the ears, but that pressure also becomes painful after some time. In the end, for me, they moved the pain to another place of the head.
I have given up solving this, and accepted to wear my LCD-XC only for short sessions. ( I like its soothing sound when I have a headache).
I do own one, I like its sound, yet I voted "not terrible", because after a while, when I wear it, the weight and pain (pressure will the carbon headband) becomes unbearable for me = not acceptable IMHO.
It is excellent that Amir put the weight chart on top position, people should not overlook this major issue.
Don't give up! The short leather strap makes all the difference in comfort, really 10/10. The headband wobbles as it is suspended now, but I could listen for hours without problem.
I think people with curly or dense hair have a more "natural suspension" and no hot spots than people with little or no hair and/or straight that don't push back up.This makes me think I either must have a dead spot on the top of my head or the shape of my skull (tall) just suits these. When I wear mine, the cups are extended to the lowest notch and things are perfectly comfortable.
I did a DIY fix on he leather headband by drilling new holes a few millimetres in (see pic).Email their customer support and ask them to sell you their shorter leather band (or DIY). Once the top of the head does not touch the headband anymore, comfort improves a lot.
If I understood this correctly: by looking at the distortion measurements at different levels in conjunction with the EQ values.I would see calling something that has a 7 to 10 db bass deficit "a distortion-less transducer" misleading.
How do you know if the bass distorts anything more or less than standard if there is no bass?
Seems like Audeze did a lot right with this one. However that weight is probably a dealbreaker for a considerable chunk of users.
Some weight is fine, but if it's heavy enough to distract the listeners from the music, it's simply too much.
For example if you listen at a volume that produces max 94dB, you know that after adding EQ the distortion would be in the area between the 94dB and 114dB graphs (assuming you don't boost by over 20dB).
Maybe someone with more well-founded knowledge can confirm or correct this.
But we already see that this is not the case with the LCD-XC, because the graph does not escalate when pushing volume to 114dB.The measurements of several headphones here show that adding 10db of bass volume can lead to an exponential increase in bass distortion.
This image is from the AKG K271 MK II review. There is a 10db difference between the blue and red lines.
That's about right @someguyontheinternet judging from the graph:If I understood this correctly: by looking at the distortion measurements at different levels in conjunction with the EQ values.
