LCD-X 2021 EQ Revisions 12-04-22
I'll be posting 2 EQs this time for the LCD-X 2021 for the reasons that one (I'll called the "Harman Perfect") I find beautiful on 95% of songs but too sharp on the 5% of songs that are mastered distastefully. The other (I'll call "Harman Truncated") is more of a one size fits all but is less detailed and lacks that Wow! factor, but you rarely get a sharp tone.
The "Harman Perfect" EQ tightly hugs the Harman Target Curve from the frequencies from 900Hz-7500Hz most notably the 'critical frequencies' from 3325-4350Hz. I did not follow the Harman Curve blindly, in fact for a long time I did not agree with much of it until by trial and error I found that if I followed it tightly there is "SOMETHING" to it that I found incredibly euphonic. Songs I'd heard 100s of times before suddenly gave me chicken skin the more I adhered to the Curve. YMMV of course but give it a try like I did and see what happens.
Now the only problem with following the Harman Curve in the critical frequencies is that it is SO detailed that you might come across the occasional Eminem type song with an over excited snare drum that is just not mastered for the Curve in those frequencies and can present as sharp and shouty. But I find for 95% of songs the whole sound is represented without too much or too little anywhere within the frequencies I adhere to the Curve. Take it as fun experiment or take it as your new overall preference, it depends on your subjective ear.
As per usual with my EQs 80Hz is emphasize to allow kick drums to cut through the mix. Sub bass is extended all the way flatly down to 20Hz for bottomless sub bass impact. 300Hz and 575Hz are emphasized to bring out the top end of kick drums and the meatier parts of snare drums respectively. Complimenting the overall sound punch and slam that the LCD-X already has.
Harman Perfect EQ
Channel: all
Preamp: -17.4 dB
Filter 1: ON PK Fc 21 Hz Gain 3.54 dB Q 1.2
Filter 2: ON LSC Fc 40.2 Hz Gain 5.4 dB Q 0.69
Filter 3: ON LSC Fc 40.2 Hz Gain 1.07 dB Q 4
Filter 4: ON PK Fc 80 Hz Gain 7.09 dB Q 1.7
Filter 5: ON LSC Fc 90 Hz Gain 7.26 dB Q 0.65
Filter 6: ON PK Fc 115 Hz Gain 2.4 dB Q 1.41
Filter 7: ON PK Fc 200 Hz Gain -3.12 dB Q 2.4
Filter 8: ON PK Fc 300 Hz Gain 3.25 dB Q 1.5
Filter 9: ON PK Fc 575 Hz Gain 3.7 dB Q 3
Filter 10: ON PK Fc 785 Hz Gain -2.45 dB Q 2.2
Filter 11: ON HSC Fc 1235 Hz Gain -1 dB Q 2.4
Filter 12: ON HSC Fc 1500 Hz Gain 8.1 dB Q 0.72
Filter 13: ON PK Fc 1750 Hz Gain 0.35 dB Q 3
Filter 14: ON PK Fc 1910 Hz Gain 1.24 dB Q 5
Filter 15: ON PK Fc 2000 Hz Gain -0.16 dB Q 5
Filter 16: ON PK Fc 2700 Hz Gain -3.07 dB Q 2
Filter 17: ON PK Fc 3325 Hz Gain 0.34 dB Q 4.8
Filter 18: ON PK Fc 3485 Hz Gain 1.67 dB Q 4.9
Filter 19: ON PK Fc 3750 Hz Gain 3 dB Q 1.7
Filter 20: ON PK Fc 3850 Hz Gain 1.05 dB Q 4.7
Filter 21: ON PK Fc 4015 Hz Gain -1.15 dB Q 5
Filter 22: ON PK Fc 4350 Hz Gain 2.5 dB Q 3.5
Filter 23: ON PK Fc 5400 Hz Gain -0.9 dB Q 3.8
Filter 24: ON PK Fc 5600 Hz Gain -1.9 dB Q 5
Filter 25: ON PK Fc 6100 Hz Gain -3.5 dB Q 2.5
Filter 26: ON PK Fc 6500 Hz Gain 2.32 dB Q 5
Filter 27: ON PK Fc 7350 Hz Gain -1.58 dB Q 3.5
Filter 28: ON PK Fc 10000 Hz Gain -1 dB Q 0.8
Filter 29: ON HSC Fc 13000 Hz Gain 1.74 dB Q 1.4
Filter 30: ON PK Fc 20500 Hz Gain 0.1 dB Q 0.7
To tailor
bass adjust the gain of Filter 5 to taste then change Pre-amp value back to -0.1.
To tailor
high-mid shoutiness adjust the gain of Filter 19 to taste.
To tailor
treble adjust the gain of Filter 28 to taste.
To tailor
high-treble sparkle/shine adjust the gain of Filter 29 to taste.
The second EQ I call the "Harman Truncated" EQ is identical to the "Harman Perfect" except for the frequencies including and slightly surrounding the 'critical frequencies' from 3325-4350Hz. You'll notice in the graph that there is a dip around the middle of these frequencies. This is to accommodate even poorly mastered songs so that when that occasion overly sharp snare or an over excited vocalist's Sss sound shows up it is not ear breaking. It is a safer EQ but lacks the extra Wow factor of the Harman Perfect EQ. This EQ is most like the past EQs that I've posted. Which you prefer is subjective but each IMHO has it's value.
Harman Truncated EQ
Channel: all
Preamp: -17.4 dB
Filter 13: ON PK Fc 1750 Hz Gain 0.41 dB Q 3
Filter 14: ON PK Fc 1910 Hz Gain 1.23 dB Q 5
Filter 15: ON PK Fc 2000 Hz Gain -0.2 dB Q 4
Filter 16: ON PK Fc 2700 Hz Gain -3.01 dB Q 2
Filter 17: ON PK Fc 3450 Hz Gain 1 dB Q 5
Filter 18: ON PK Fc 3750 Hz Gain 3.1 dB Q 1.7
Filter 19: ON PK Fc 4007 Hz Gain -0.45 dB Q 6
Filter 20: ON PK Fc 4350 Hz Gain 2.4 dB Q 3.5
Filter 21: ON PK Fc 5400 Hz Gain -0.9 dB Q 3.8
Filter 22: ON PK Fc 5600 Hz Gain -1.9 dB Q 5
Filter 23: ON PK Fc 6100 Hz Gain -3.5 dB Q 2.5
Filter 24: ON PK Fc 6500 Hz Gain 2.32 dB Q 5
Filter 25: ON PK Fc 7350 Hz Gain -1.58 dB Q 3.5
Filter 26: ON PK Fc 10000 Hz Gain -1 dB Q 0.8
Filter 27: ON HSC Fc 13000 Hz Gain 1.74 dB Q 1.4
Filter 28: ON PK Fc 20500 Hz Gain 0.1 dB Q 0.7
To tailor
To tailor
high-mid shoutiness adjust the gain of Filter 18 to taste.
To tailor
treble adjust the gain of Filter 26 to taste.
To tailor
high-treble sparkle/shine adjust the gain of Filter 27 to taste.
I know and have already been told ad nauseam that I use a lot filters and have large pre-amp values. I use a lot of filters because I have an anal retentive ear and I also develop my EQs so that aspects of them can be changed with a single filter if so desired. Also with the attached .txt file all you have to do is use the import function in PEACE to avoid having to manually enter values! I have a large pre-amp value because I love sub-bass and find it fun. This is not for everybody I know which is why I make it easily adjustable to taste. I have not noticed any sound degradation using Equalizer APO and I've been working in sound engineering for over 25 years. I have no more to say about that.
A great song to appreciate the "Harman Perfect" EQ with is this Sarah McLachlan song, "Prayer of Saint Francis":
Remember that I am not selling anything, just sharing my appreciation of the headphone experience. Nor am I preaching that you
must EQ. Each person has their own opinions about that and I respect that. Please respect my choice to EQ and if you're also a proponent of EQ, do try them out and see if maybe there is something there that you like! Happy Listening!!!
Blessings,
-Jonne
