ATMOS bounce speakers and movies with overhead effects
RDoc
I'm almost exclusively interested in ATMOS music, but a friend of mine is very into action movies so we've been discussing ATMOS indirect vs ceiling speakers. My system is 5.3.4 with indirect bounce speakers which has been Dirac tuned. Because of the room layout, the side speakers are at 180 not behind us, so that's a limitation.
However, after listening to Mannheim Steamroller's Rain Dance album and clearly hearing thunder moving from the left side, across the ceiling in front of us, and ending off to the right front, then rain falling overhead, I decided to try some movies. I tried 6 Underground and The Adam Project and while I can't recommend the movies, the overhead effects were very much there. In my case they were overhead and in front, not really directly overhead, but definitely above me.
I've no doubt that real ceiling speakers would produce a much stronger effect, but I'm surprised at how well the indirects work. I've not messed around with more balancing, but strongly suspect the Dirac helps a lot.
The affrect will definitely increase with overheads. I dont have overheads set up currently because the space is temporary. I am using an atmos pair that I had on the ceiling. They open up the sound field and allow the processing of Atmos, Auro. I love the music in Auro 3D and Atmos. I get some decent panning and affects on films. If you are a film lover, I would definitely try for the ceiling if you can. Just my two cents.
