depends on location- the prices in the UK aren't bad but here in the US they're about double the UK!More so, that they are ridiculously over-overpriced.
Buying local makes sense again.depends on location- the prices in the UK aren't bad but here in the US they're about double the UK!
Did you get to hear them after all your posts?
Oh stop it, please! We know you dislike ATC. If a Kii Three or one of the other domestic favourites such as D&D goes t*ts up in a few years, I wonder how easy it might be to get it fixed, espedcially if the Hypex? amp modules are no longer made or the company itself if an EPROM needs replacing no matter how unlikely. Same for the drivers unless they're SB or similar stock parts?
I didn't know it then, but the ATC 100A's I loved thirty years ago can still be fully serviced and updated today, from amp packs to drivers if needs be. The amp packs (which run quiet through the tweeters by the way!) shouldn't ever be an issue and I've seen other UK speaker repairers working on ATC-like drivers (not sure how different the Audax mid dome that PMC used is to the ATC original. The bass units are all but indestructible out in the field (the 15" foam surrounds go though as they all do) although an amp failure with DC at rail level going in will kill them.
Of course, living in the far east and distanced from the factory may well turn your head to other modern brands, but just because ATC currently don't use DSP or other fancy tech doesn't mean the speakers are crap - and I for one have never EVER dismissed what the likes of Genelec and Neumann are doing at lower prices, believe me I haven't! I look even lower at the sub-£/$1000 wonder-boxes coming along and wonder just how good, or not, they really are
No matter to me as this brand's pricing is beyond me now and herself doesn't like the looks of the 40A's, so ruling them out despite them being a good size match to our room. I don't see why we can't have a fanboy thread about them with some objective comments, praise and criticism where necessary. Me? For whatever subjective reason, I can 'live' with ATC's way of doing things (even the 11's which seem better balanced mid-bass to upper-midrange than the 19 and 20) easily. It remains ot be seen (or heard) if I'd find Genelecs or Neumanns so easy to listen through (Kii's look too oddball as do D&D's and price rules them out as well). Just PLEASE don't criticise for the sake of it! Cottage Industry Crap is below the belt for a brand such as ATC, even if it may be falling behind a bit.
And...?A recently deceased Hungarian engineer, who changed his mains from Genelec to ATC (and always dismissed room correction):
Can you help with translationA recently deceased Hungarian engineer, who changed his mains from Genelec to ATC (and always dismissed room correction):
The dome is narrow band and is used almost wide open with little to no room for crossover overlap. the revised (twenty years ago) curvy waveguide may well help here, but there were/are resonances just above the usable range of said driver coupled with an early roll-off at the lower end (there was an extremely heated thread on the long defunct Zero Gain forum about it with response plots presented, challenging the almost religious admiration of said driver), which may explain why many plots of ATC speakers show a bump-up in response in the middle of its passband.@DSJR
Can you tell me what you mean by the “fussiness” of the ATC’s mid dome?
To me, the mid is the best I've heard from any speakers. Voices and instruments sound very convincing with a sense of a three-dimensional quality to them, meaty and life-like.
And "we" don't understand this ATC hype.And...?
I only posted to illustrate the switch to ATC. (Both are presentations of the studio gears.)Can you help with translation
Seriously, what makes you think that?People used (and still use) NS-10s for mixing. Once again, it's not because they're the best speaker. I can believe ATCs serve a similar purpose. Not at all sure that's a compliment.
No, people here have commented that Genelecs can be too forgiving in a studio. I imagine that is true for a lot of the more refined monitors. You need some idea what your mix will sound like in the real world, like in a car, or listening on old white van speakers, or rocking out to Bose cubes. Most end-users don't know or care about high fidelity.Seriously, what makes you think that?
I guess you think the same about all speakers that are popular in music studios like Genelecs, Focals, Neumann etc. You should probably avoid them all!
What type of speakers do you use at home?
What I've heard, it's a bit of a misunderstanding why the NS-10 was so popular in studios. It wasn't because they sounded like something the general population had at home, they worked more like a magnifying glass for the midrange, and if the mixing engineer didn't hear anything wrong with those speakers, the mix would most likely not sound bad on anything else.No, people here have commented that Genelecs can be too forgiving in a studio. I imagine that is true for a lot of the more refined monitors. You need some idea what your mix will sound like in the real world, like in a car, or listening on old white van speakers, or rocking out to Bose cubes. Most end-users don't know or care about high fidelity.
I built my own active MTM speakers, from a witches brew of RSS390HF-4 woofers, W180E001 mids, and TAD TD2002 drivers on 511 horns. They use an RCF DX-2006 DSP.
You know most of the reviews back in the day use to quote that ATC are too revealing because of the studio character therefore not ideal for home use...People used (and still use) NS-10s for mixing. Once again, it's not because they're the best speaker. I can believe ATCs serve a similar purpose. Not at all sure that's a compliment.
Yes, they have a peak around 1.5kHz, which gives them a forward sound.What I've heard, it's a bit of a misunderstanding why the NS-10 was so popular in studios. It wasn't because they sounded like something the general population had at home, they worked more like a magnifying glass for the midrange, and if the mixing engineer didn't hear anything wrong with those speakers, the mix would most likely not sound bad on anything else.
It was also a small portable speaker that freelancing engineers could easily take with them, just for a reference if they had to work with monitors they weren't used to.
I don't think many productions were made with the NS-10 as the main monitors, a full-range speaker is needed to hear the full spectrum in most cases.
This article goes in-depth about the NS-10. If you look at the measurements they had a really good transient response, which was probably one of the things that made them a good “studio tool”. Fast, brutally revealing tools that made faults in the mix stand out.
The Yamaha NS10 Story
Love or hate the Yamaha NS10, this unassuming little speaker has found a place in the studios of many of the world's top producers. We trace its history, and investigate why a monitor whose sound has been described as "horrible" became an industry standard.www.soundonsound.com
