ATC speakers / Monitors
85db speaker hits 100db with 32w so you really don't need much power at all to make a speaker like that loud in most spaces.
It's not that simple, impendance has a huge influence, and this speaker does not have a flat 8 ohm impendance. Impendance swings between 6 and 20 Ohm so you You will need a bit more to drive them to full potential. And you need headroom to not distort the amp. I would say that a +250W amp is what is needed to drive this speaker to full potential with all the headroom that is needed.
It's not that simple, impendance has a huge influence, and this amps does not have a flat 8 ohm impendance. Impendance swings between 6 and 20 Ohm so you You will need a bit more to drive them to full potential. And you need headroom to not distort the amp. I would say that a +250W amp is what is needed to drive this speaker to full potential with all the headroom that is needed.
What is "this amps" and "this speaker"?
I've had typical 2 ways and large 12" 3 ways on these amps and they all did fine, varying impedances. No distortion heard and nothing measured out of the ordinary. I'm sure full potential is somewhere between uncomfortably loud and hearing damage lol.
100dB at 1m. These are not nearfields, so expect 2-3m listening distance. The math in free field is pretty simple (double distance, SPL drops off by 6dB), but real-world isn't. Either way, 100wpc is probably the bare minimum I'd want to use in a typical situation with SCM50 passives.
Trust me, you will forget about 100w amp very soon if you had scm50 at your disposal.
I wouldn't bother with anything under solid 200w and that is for home, for pro make it double...
Actually 103dB since unlikely to be listening to just one speaker. Then another couple of dB for room gain. That difference of 3dB between the 100 watt amp and the 200 watt amp starts to become inconsequential. Not impossible there would be a situation where it was make or break, but....
Still it's better to have the power and not need it than need it and not have it.
I have the active 20 Pros. ATC fits them with 50w for each tweeter and 200w for each woofer, so 500w in total for the pair. I've never seen the red clip lights come on in mine no matter how hard I drive them, it would be deafening I'm sure!
So that's 250w per side, like i said. And that is the small one, the big one probally can use more watt.
So you are saying that a 40 watt a channel amp with no head room would be just fine?
Maybe, if you only sit in that one spot to listen and never. ever, turn the volume up (perhaps because you want to go to the kitchen to get a snack while still hearing music).
I would never trust my-self to sit in one place for more than 5 minutes or so. (or even be in the same room for more than 10-15 minutes (unless it is a more formal dining room with both food and other people or the bedroom, where I would most likely be asleep.
But I may (and mostly do) have the volume up so that I can hear the stereo when I am moving about (including turning it up more), when I go out on the deck.
It would be sad to have less than 100 watts available at 8 Ohms (even with very efficient speakers).
(not to worry, I have many amps: none of which that can deliver less than 250 watts RMS into 8 OHMS (and much more into both 4 and 2 ohms).
All are rated by the manufacturer as being able to do two ohms.
Thats not what I said at all. How did you pull that from what I said?
Gotta love the user who made an account here just to make pro atc posts lol.
I don't see how one could not draw that conclusion from you stating that 32 watts hits a 100 DB. To me (and everyone that I asked in person [6 people)], myself felt that you are indicating that there is no use case for anyone to use more power than that.
The lowest power amp that I can think of is the Grandson of Ampzilla (that I believe is 40 watts a channel).
So naturally I had to ask.
If that is not what you are saying, and you are just stating a fact for (which to me seems to have no apparent reason for it to be stated), (or if there is a reason that for you stating that),
then obviously I am not understanding WHY you made that statement.
I just said a speaker of that sensitivity can hit 100db with 32w. You guys can make up whatever you think I said, but it wasn't "32w is all you need". My point was 100db @1m is more than enough for most spaces and users. If it's a bookshelf, you can't really go much higher than that anyways. Go ahead and spin that whichever way you want.
I made that statement because I saw people being silly about wattage and wanted bring some perspective.
Ok. I got it. Thanks for explaining.
I thought that it was sort of like the Beatles "All You Need is LOVE" (as in "All You Need is 32 [watts]).
So it was just a statement of capability.
With a very efficient pair of speakers, I have made 112 DB with 18 watts a channel (8 Ohms).
But was it accurate? No! Was the amp section clipping? YES!
I am a big believer in excessive available power to prevent amp clipping for large dynamic range changes.
(And none of my 7 amps can peak at less than 400 watts RMS).
Just keep your amplifiers strong, speakers big and cables tidy and let the music do the rest :-)
Reactions: EJ3
Has anyone here listened to the SCM300ASLT or the passive version? I’m very curious to hear someone’s impressions :)
Only once at a fairly famous musicians house, in a small room completely dominated by standing waves.
I offered to help but …
I've heard the 200ASL Pros, the 110ASL Pros, and the 150ASL Pros.
They're all pretty similar sounding, the 110s seem the best balanced of them but they were also in a *substantially* better room in the low end.
Working with them regularly. Very impressive, even if the room is not ideal, but then, is there such a thing?
Can’t say that they are my favorites, I still much prefer 150s and 50s, and consider those best speakers by company. But 300 in-walls can pump some air. :)
