Uh-huh.
These are Klein&Hummel speakers, don't know how long these speakers were in production.But for those who have K&H O300s or O410s, you pretty much can't get parts for them - Neumann/Sennheiser don't have them. If you blow a woofer (which does seem to happen on the O300s...), you're cooked. Genelec and ATC keep stock around for older speakers, I can't say I've seen the same from Neumann/Sennheiser.
Uh-huh.
I would mind only if it was the original "Uh-Huh©" owner, @SIY , who actually measures stuff.Please stop treating ASR as if it was your personal little Facebook messenger conversation. Answer people with a proper reply instead of these short and meaningless responses. This forum deserves more quality.
Just put them on ignore like I didPlease stop treating ASR as if it was your personal little Facebook messenger conversation. Answer people with a proper reply instead of these short and meaningless responses. This forum deserves more quality.
The KH420 replaced the O410 in 2014, KH310 replaced the O300 in the previous year.These are Klein&Hummel speakers, don't know how long these speakers were in production.
I probably have 50 including some of the most prolific (and boring) writers.I only have two members on my ignore list, and for a few months, I also had a certain dealer on that list too. But I find the forum gets somewhat broken when I’m not able to see what it is other members respond to when they reply to these ignored members of mine. I shouldn't have to be the one who has to tear down the forum.
Agreed, it has periods where the discussion gets more technical and then just reverts back to the same core group of trolls bleating the same stuff over and over again. Very tiresome.
Ultimately it's their way of causing trouble because they don't like the brand. Keith has commercial reasons to be like this too remember...
We have members who own or use atc speakers, they mainly share the experiences they have gained in practice using atc.
The second group is those who do not own or use atc speakers, but are very critical on atc.
Discussions between the two group are tiresome, conflicting, and, as a rule, slip into a tone that nobody, I hope, wants.
I own an atc speaker but I am not encouraging anyone to buy an atc. Because I see atc more as a pro speakers (classic series) then hifi. I feel the character of their sound are more align with studio requirements then to typical hifi set up.
However, I don't understand the motives of some members who neither own nor use atc speakers but still persistently participate in these discussions, endlessly complaining on anything atc.
They don't have atc speakers, don't have measurements of them, don't have desire to buy atc.
So I wonder, what is the basis of their discussions?
I have one criticism of ATC loudspeakers, just like with most other loudspeaker manufacturers, for that matter, and that is about where the height of the acoustic axis ends up on different speaker models, depending on how they are designed. When I optimize my loudspeakers in my listening room, I want to make sure the acoustic axis of my ATC loudspeakers ends up at ear level at my optimal, most critical listening position, as recommended in the manual.
For all the 2-way ATC speakers, the acoustic axis is at the midpoint between the bass/mid driver and the tweeter, while the acoustic axis for all the 3-way ATC speakers is at the height of, or a bit lower than the mid-dome driver. The recommendation, which is stated in the manual, the acoustic axis should be at the ear level or up to 5 degrees above the ear level.
This is, of course, not a problem with the smaller 2-way and 3-way models that can be easily positioned at the most optimal height just by using a speaker stand with the correct height for the particular speaker model. But when it comes to the floor-standing models, there is a lack of continuity from speaker to speaker where the height of the acoustic axis ends up, and that is even the case with their classic series of speakers that comes with a stand.
The height of my ears at the listening position is at 91 centimeters above the floor, but I think my sofa is quite low, so the average height is likely a bit higher than that, and probably around 95 centimeters. When I use spikes and Linn Skeet flor protectors, the midpoint of the mid-dome driver of my SCM40s is at 84 centimeters above the floor. To solve that when optimizing the setup, I have tilted the speakers by maximizing the length of the spikes on the front of the speakers, and minimized the length of the spikes at the back of the speakers. This is enough to point the mid-dome driver at the height of my ears at the listening position, which I have confirmed with a laser measuring device.
What I can see in pictures of the SCM50, the mid-dome driver is placed even lower than it is on the SCM40, approximately about 3-4 centimeters lower. I don’t understand why ATC didn’t just make the stand 10 centimeters taller, or maybe even letting the customers making a custom order for the height of the stand, as these speakers are usually made on order anyway.
As I said, this is not isolated to ATC. Here’s an example of the Revel Performa Be series of speakers, which have their acoustic axis at the height of the tweeter drivers. The acoustic axis is all over the place with this speaker line.
And the AsciLab 8C8/BX8C combo, which at least will have the acoustic axis 108 centimeters above the floor.
Yes, I know that all these loudspeakers have a acoustic “window” that allows for some margins, but if you really want to truly optimize for the absolute best possible sound, that will be listening at the same height as the acoustic axis of the speakers.
The closer you are to the speakers, the larger difference it makes to optimize this. For me who optimizes my speaker setup for a high ratio of direct sound, the listening distance is only about 190 centimeters between the speakers and my ears.
I agree it’s a fairly common design weakness - or characteristic if being charitable - of many speaker ranges. I’ve had my SCM40 on plinths - actually Sonus faber ‘Stones’ made for long departed Concerto Grand Piano speakers - since I first got them. They add about 5cm which suit my ears, and I can use the speakers without spikes which I’m not mad on at home. It’s much easier to tweak toe-in etc without, and I intersperse the base of the ATC and the plinth with a sheet of rubber mesh - that stuff sold to line drawers with to deaden noise and avoid slippage.The height of my ears at the listening position is at 91 centimeters above the floor, but I think my sofa is quite low, so the average height is likely a bit higher than that, and probably around 95 centimeters. When I use spikes and Linn Skeet flor protectors, the midpoint of the mid-dome driver of my SCM40s is at 84 centimeters above the floor. To solve that when optimizing the setup, I have tilted the speakers by maximizing the length of the spikes on the front of the speakers, and minimized the length of the spikes at the back of the speakers. This is enough to point the mid-dome driver at the height of my ears at the listening position, which I have confirmed with a laser measuring device.
...and ATC is sought after typically by the less knowledgable engineers.
I was at the same show and thought they were pretty good. Certainly one of the better rooms at the show. I was there Sunday maybe you heard them the day before and they'd sorted the issue since? My colleague also liked them (and he doesn't like anythingSaying all that, i did listen to a pair of the ATC special edition 50 (Elipse shaped £50k!) recently at a hifi show, they sounded pretty dire, lean and shouty.
