RexrothPigeon
- Joined
- Mar 21, 2025
- Messages
- 1,427
- Likes
- 2,985
Real voodoo audio hours
Depends,Real voodoo audio hours
When using massive, heavy stands, I think the point is not to decouple speaker from the stand. Rather, the idea is to firmly stick the speaker to the stand (blue tack balls do a great job of this), so that the speaker and stand become one piece. In this way, the large mass of the stand prevents the speaker from making small movements, which leads to a cleaner sound.I’m not sure it's that important to use massive or heavy stands, at least not as long as the loudspeakers are decoupled from the stands using effective dampening feet, which isolate them completely by lowering the resonating frequency below what the loudspeaker is capable of reproducing.
I use dampening feet made of Sylomer, which do just that. They come in different weight classes and look like this:
The only way to know for sure if there's a real audible difference is controlled blind testing.If there's a real audible difference when using them vs not using them
plus, by the look of them they probably won't be in the "snake oil" price category
This is only an issue if you are actually hearing rattling or buzzing. If you are not hearing that, then it's pure snake oil and you shouldn't waste any money or time or effort on it.small movements, which leads to a cleaner sound.
Blue tac is the work of the devil here!!! - NOT because it doesn't work, but because the stuff gets in the woodgrain on some wooden finishes and is there for life as you can't get the effin' stuff outWhen using massive, heavy stands, I think the point is not to decouple speaker from the stand. Rather, the idea is to firmly stick the speaker to the stand (blue tack balls do a great job of this), so that the speaker and stand become one piece. In this way, the large mass of the stand prevents the speaker from making small movements, which leads to a cleaner sound.
As is usually the case with business like this, results may vary, but it worked for me.
I still have blue Sylomer left over, from a studio I built for a client in Miami in about 2000 - still good. You can literally rest a buildings foundation on it, I have seen it in such applications, when a building is close to train tracks... Amazing stuff.I’m not sure it's that important to use massive or heavy stands, at least not as long as the loudspeakers are decoupled from the stands using effective dampening feet, which isolate them completely by lowering the resonating frequency below what the loudspeaker is capable of reproducing.
...the stuff gets in the woodgrain on some wooden finishes...
I made heavy duty stands for scm50, same height but 20kg each....I have SCM50s which when placed on budget decoupling devices (chunks of foam etc) actually results in a marked rise in harmonic distortion at the listening position. A friend noticed the same with his SCM20 actives (also for studio work). He might still have some measurements he could send me...
The science behind how to do it correctly is very straightforward if you know a bit of physics. Most of the 'solutions' on the market do no good however. There's even of a video of Ben Lily from ATC talking about how most products out there don't work.
Some links:
Wikipedia - Vibration Isolation
Acoustic Insider YouTube channel - less scientific and more just a practical discussion but the same kinds of things mentioned - you need to know the mass of your speaker system and the 'springiness' of the isolation mechanism in order to make the whole thing work properly.
Gearspace discussion - Thomas of Northward Acoustics talks a bit about what does/doesn't work and some of the challenges you encounter in trying to do this effectively
This one?the response looks a dogs dinner by ASR standards, but is actually really good by the standards of the cr@p HFN usually measures!
In fact, if we normalize this to the same scaling as Amir uses...This one?
Note the 30dB scale and the expansion to 40kHz.
By a normal 50dB scale, it would look more than decent.
Yes, the range should cover 60dB to 90dB of Amir's chart.Agreed that it’s acceptabel, but it’s not as good as the Photoshop work suggests
So,The only way to know for sure if there's a real audible difference is controlled blind testing.
Snake oil isn't about price. It's about bullshit claims.
So,
It's still about ... "do they make an audible difference or not", that's all i said, if they don't or make the sound worse it's snake oil regardless of price.
Me too - the purpose of a blind listening test is to see if the perceived changes are real. With speaker isolation, supports, stands etc I'd say most of the time they're not real. Unless two stands put the speaker at a different height or speaker was sat on something that is very resonant.I’m sure no one will need a blind listening test to hear the changes.
