Nothing apart from the cabinet and the price I believe.
just the cabinet and using a discrete instead of IC op-amp based crossover, I think.They look great indeed, do you know what's the difference with SCM50 ? Same driver for the Low End ? I assume they're 50L as well considering the name.
The EL150 is old enough that it came with the Seas t25cf001 instead of ATC's tweeter.KeithEL150 - ATC Loudspeakers
Overview ATC SM-150s Soft Dome Mid driver ATC Super Linear 375mm Bass driver Massive hand made motor assembly Wide dispersion for perfect imaging Cabinet designed to eliminate edge diffraction and internal resonance Original owner, lifetime guarantee Any veneer to order Featured veneer: Burr...atc.audio
Cabinet is where the cost go. If you can live with square box, cheaper scm50aslt is you ticket.
Unlike others perhaps, that's one fugly box - there was a 15" bass driver version some years back as mentioned above which to me was even more fugly!New ATC for Bristol show, I say ‘new’ but … £50k you get a book with it.View attachment 512107
So worse then? The great unwashed do still seem to prefer discrete circuits to properly designed chip based, don't they... As for DSP, the horrorand using a discrete instead of IC op-amp based crossover, I think.
It's a classic trick to cash on new designs, with first a very expensive limited edition and then a slightly different in looks general model that is not limited in numbers and a lot cheaper priced. They do this trick for a lot of products, even vinyl resleases with a limited edition coloured vinyl with a special cover, and then a simple black vinyl with a more basic cover. The first run becomes a collectors item that can be resold for high inflated prices...I think it's nice that they provide special edition models for those who are interested in such things, even if that isn't a thing for me personally, or maybe I just don't have the economy for anything like that.![]()
