ATC speakers / Monitors
Everyone would like to see some complete measurements from ATC.
Well Genelec are pretty new too ( also 1974 I believe) and they managed it.
Have ATC ever stopped anyone from measuring their loudspeakers?
If someone convinces Erin to review a pair of ATCs of your choice, I’m sure he will be able to do so.
I don't believe so,
I own a pair of SCM 40MkI's and I want to get rid of that horrible Vifa/Peerless tweeter by changing it to something else (Going probably for a Raven Point Source, as cossover points and sensibility fit perfectly with the SM75-150), and as I do this, also add a Subwoofer in the whole cabinetry, I measured T&S Parameters for the bass driver, sent my measurment to ATC's technical pole email, and they confirmed it plus gave me the Xmax value I asked for.
They're truely nice people, so that would be strange if they stop anyone from publishing measurments, as they seem to measure truely well from the few I took.
The pertinent question is, why haven’t ATC measured their speakers themselves or sent them to be measured by an independent third party.
ATC do provide some performance data for their models so it's not that no measurements have happened. Whether more have been made in-house or elsewhere is not something we can know though, only that they haven't published any.
Not quite true, since the on-axis response will vary with distance due to the different path-lengths for mid and tweeter to the microphone. I was making gated measurements at the distance of my listening position as this is where I personally care about but it's something I need to find time to get back to doing properly. I had a more pronounced dip in the tweeter-mid crossover region which I want to double-check, and test for both speakers. From my initial test it was pronounced enough I was considering experimenting with some EQ to reduce this.
I have the speakers toed in to point directly at the MLP by the way. Do you not?
Edit: I should add I was making measurements at the mid-driver height - I appreciate height will affect the crossover region significantly. I actually investigated by how much. My listening position is higher than the mid-driver when normally set up, so I have now tilted the speakers back so that the MLP is on the mid-axis.
Height of measurement is absolutely a thing, gated, multigated or not:
(same at 1/24)
(the purple-yellow difference there can make a difference between a speaker and a chainsaw :p )
Where?
Open any product page on the ATC site and look at the specification section. No it is not as extensive as you'd want but those numbers have come from somewhere...
Specifications aren’t measurements.
Out of a hat?
Where are actual measurements it is 2026.
Out of a hat?
Don't be obtuse. These figures are very obviously performance stated from measured data. There is no other appropriate way to do this.
That is rather the point isn’t it, where are the measurements why don’t ATC publish them?
What ultimately matters is the sound power response and the early reflections directivity index. Without these, it is not possible to meaningfully evaluate a loudspeakers performance. Additional measurements like compression tests and IMD tests would also be very helpful.
That's rather weird for sure, but there might be a reason.
Ever tried to send them an email to ask them actual measurments ?
As said, I measured T&S Parameters + Impedence curve on one older Bass module for SCM40 MkIs and they approved it saying it matched theirs, plus gave me the Xmax parameter.
