Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,032
- Likes
- 10,513
- Thread Starter
- #5,521
Why do they stick to soft domes and not move to metal domes?
Well these days they're making them in house, and doped cloth is easy to deal with. They'd have to contract out diaphragm manufacture.Why do they stick to soft domes and not move to metal domes?
Justs confirms what listening experience of thousands of users and some of us here are talking about all these years.If we ignore the soft dome beaming, they measure pretty good actually.
Zero experience with the small ones but what we see pretty much correlates with decades of talks about ATC minus the dome mid.It appears our good friend @Nuyes has measured the SCM20SL Mk2.
It is considerably better than the SCM19 reviewed here.
That's encouraging.Apparently ATC have approached a U.K. Klippel NFS owner.
The off axis flare and diffraction artifacts around 4-6k would have been lessened some.It seems these were measured with the grilles removed which leaves hard-edged baffles. The grille has a rolled-edge built in behind the cloth (which is then supported from a very thin frame sitting in front of the whole speaker). Without this you're going to wind up with edge-diffraction issues
I wonder how the off-axis measurements would have differed if they'd been measured grilles on.
Uhm, what's the possible deviation from true accuracy? Measuring speakers often means in several cases you have a possible +/- 1dB accuracy envelope. 0.3dB is well below something that can be accurately and repeatably measured in several cases...?The matched pair, with a deviation of only about 0.4 dB (and for the most part around 0.3 dB), is also quite impressive for a pair of passive speakers. The reviewer said it was the best he had ever measured. That makes for a very precise and stable stereo image.
Thanks for finding and sharing this. I'd LOVE to know how the active Pro versions (what I use and am very happy with) measure in comparison.It appears our good friend @Nuyes has measured the SCM20SL Mk2.
Probably similar, albeit with less edge diffraction nonsense around 4-6k.Thanks for finding and sharing this. I'd LOVE to know how the active Pro versions (what I use and am very happy with) measure in comparison.
I think the tweeters may be slightly different too, seem to remember reading somewhere (maybe the ATC site) the pro versions have greater power handling or something. Ah, here we go:Probably similar, albeit with less edge diffraction nonsense around 4-6k.
Near wall placement grilles usage and compression must be taken into account.Zero experience with the small ones but what we see pretty much correlates with decades of talks about ATC minus the dome mid.
Lean, controlled bass, low distortion, good higher SPL handling, picky about placement, etc.
These ones seem bright too on-axis and as they are pretty small (so better for nearfield) , I wonder if someone can get around it placing them so the on-axis excessive highs get a self or DSP them at such way.
Grilles showed strange results at the measurements, I'm not sure they are usable.Near wall placement grilles usage and compression must be taken into account.
Ultimately the pro versions are the better versions here; they have proper roundovers without grilles.Grilles showed strange results at the measurements, I'm not sure they are usable.
It's surprisingly even until it beams, and boy does that happen violently.Tweeter dispersion on that bookshelf is mighty poor.
"The standard SH25-76 and its ultimate 'S' spec stablemate approach these engineering challenges in different but equally successful ways. The standard tweeter has a novel and lighter moving mass bracing component, while the 'S' spec driver has an exceptionally powerful motor assembly that, when combined with the optimally stiff and lightweight coil former, delivers vanishing low levels of odd harmonic distortion and a well controlled extended frequency response beyond the limit of human hearing."
