Blockader
Probably you are talking about off-axis measurements.I know I have posted my directivity measurements of my ATC SCM11s before, but here we go again. Can anyone see any severe directivity problems of these loudspeakers crossover region at 2.2 kHz?
You know these already but I would like to add a bit more information for goat76:Not at 2.2 kHz but higher, also for the directivity the vertical one is needed.
All the three ATC models for which more detailed measurements exist show not great performance there.
Measurements for speaker ATC SCM19 v1
www.spinorama.org
Measurements for speaker ATC SCM20SL MK2
www.spinorama.org
ATC speakers / Monitors
I'd imagine they would do well to get a Klippel (if they don't have access to a decent anechoic chamber already) for R&D purposes. The Klippel NFS just makes things faster and can be a help and addition for precision for the bass region if you don't have either an anechoic chamber or open big...www.audiosciencereview.com
In-room measurements are pretty much useless for almost anything. Because direct sound is perceptually dominant over reflected sound in human auditory perception, the summation of both doesn’t really tell you how well speakers perform. An on-axis error can be masked by the reflected sound in the summation, but that on-axis problem will still be audible due to the dominance of direct sound. Similarly, a directivity error can appear corrected because of different absorption coefficients in someone’s room, but its coverage will still affect the impulse response which determines overall clarity and envelopment. There are more reasons why in room off-axis measurements are useless, but I’ll leave it at that for now, this post could get far too long otherwise.
I can't even see the off-axis angle in those measurements also. But even then, they are pretty much useless to determine anything.
