Yours actually look better (well I don't really know because nothing higher than 5 khz included for some reason).
I'd prefer higher resolution and some frequencies higher than 5 khz included.
Are ATCs V-shaped in general? Yours have some bass boost and what is in higher frequencies?
They measured from 4 meters, so shouldn't be a problem at all.You'll note I just quoted a graph posted earlier in this thread - I don't know the source. I missed that the graph didn't go above 5 kHz though - it's a bit odd the full range wasn't plotted to be honest.
One general thought on some of the data shared is that I wonder if the 'on-axis' measurement position is always at the height that ATC may have designed for.
So an honest speaker should sound, wow, such lack of clarity in the midrange? That makes no sense to me. Honestly, the uninformed graph-peeping here really isn't helping. Modern active ATCs work very well, for their intended professional task. Rather than handwaving about how that must be impossible, you should figure out how it is in fact a reality.A honest speaker should not sound '' very wow, such clarity in mid range ''
Maybe you need to deal with the reality, ATC doesn't have any flat speaker.So an honest speaker should sound, wow, such lack of clarity in the midrange? That makes no sense to me. Honestly, the uninformed graph-peeping here really isn't helping. Modern active ATCs work very well, for their intended professional task. Rather than handwaving about how that must be impossible, you should figure out how it is in fact a reality.
Figure out how exactly? There are no detailed measurements existing. And when there is, then it doesn't look convincing.Rather than handwaving about how that must be impossible, you should figure out how it is in fact a reality.
No speaker in all of human history has ever been flat. Stop dreaming, start figuring.Maybe you need to deal with the reality, ATC doesn't have any flat speaker.
That's a weird question, on a science forum. I thought figuring things out was the point!Figure out how exactly?
The fact that atc is a good pro speaker is not a question.So an honest speaker should sound, wow, such lack of clarity in the midrange? That makes no sense to me. Honestly, the uninformed graph-peeping here really isn't helping. Modern active ATCs work very well, for their intended professional task. Rather than handwaving about how that must be impossible, you should figure out how it is in fact a reality.
let me re write my statment: Maybe you need to deal with the reality, ATC doesn't have any near flat speaker.No speaker in all of human history has ever been flat. Stop dreaming, start figuring.
I, too, am disgusted with the lack of linearity in FR obtruded by ATC on the pollyannaish listener. Outrageous, i say, is the audacity with which ATC deceives it's customers. How dare they not deliver +/- 0.2dB linearity, for i can clearly hear differences greater than that in my anechoic living room? How much more must ATC customers endure? How long must ATC customers accept the domination of ATC marketing over common sense?Maybe you need to deal with the reality, ATC doesn't have any flat speaker.
Exactly. Then, with open minds, we need to examine how the measurements relate to the reports from the field. We might learn something important.After all the controversy in this thread @amirm must measure a pair of scm50 somehow
I was in the process to send Amir one of my SCM19 v2, but the risk sending them from Germany to burgerland snuffed the life out of the idea. Also, shipping costs, tariffs and so on.Exactly. Then, with open minds, we need to examine how the measurements relate to the reports from the field. We might learn something important.
Then maybe we should ask if "flatness" is as important as lay intuition suggests. Literally billions of hours of collective experience is that it isn't. You have a choice whether to pursue that investigation, or cling to lay intuition and ideology. Up to you.let me re write my statment: Maybe you need to deal with the reality, ATC doesn't have any near flat speaker.
Then there is a lot of pro's not using ATC. Look at Dave Pensado and his studio facility he did a tour of. I could be wrong but I do not recall seeing a single ATC speaker there. That was amongst other in the facility to.Maybe you need to deal with the reality, ATC doesn't have any flat speaker.
Does this tell youMaybe you need to deal with the reality, ATC doesn't have any flat speak
Did you have an audition of one of the 3way?Figure out how exactly? There are no detailed measurements existing. And when there is, then it doesn't look convincing.
There is no ground to even make some theory.
