The number in the model name is the cabinet internal volume in litres so the 100 has twice the volume and 150 3 times the 50.Damn
Now I wonder how big are the 150s
that competitor dome is not really comparable. It's overhung, is open-back (so the LF response is not accurate to when in a sealed housing), but also it can't extend anywhere near as low because its maximum linear excursion is 0.5mm. Maybe in a deep horn/waveguide it could be OK...
https://www.madisoundspeakerstore.c...speak-discovery-d7608/9200-10-3-dome-midrange
A better comparison would be the Bliesma M74S, but that still has way less linear excursion (+/-1.2mm vs I believe +/- 3mm) and should be crossed higher. Again, a waveguide/horn could improve that LFX dramatically.
Yep this is the most similar I've seen (well, mostly).This one is likely most close to ATC:
https://www.madisoundspeakerstore.c...k-ellipticor-d8404/552000-84mm-dome-midrange/
Attention! The price is: $2,549.50
Internal design. Underhung coil, shorting ring (vs ATC's SLMM ring which largely accomplishes the same thing), double suspension.
The Volt waveguide is actually different from the ATC, the former being straight and the latter being curved at present. The very old ATC waveguide was straight.About the only thing the Volt shares in common is the double suspension and the small integrated waveguide.
Although this is the non-S version, it's still very good. Smooth frequency and impedance response, even dispersion, low harmonic distortion etc. Plus there is a rare feature amongst dedicated midrange drivers and double suspension drivers: this (and also the S version) have a very high Qms, which usually means very low mechanical losses (the higher the Qms the lower the mechanical losses all else equal), I bet you can't find a midrange driver with higher (or similar) Qms than the ATC mid-dome have.Some measurements
This is an old SM75-150 with the straight waveguide, it can be even more than 40 years old.How much is the driver new ?View attachment 380446
Yes the units in my 42 year old ProAc EBS are like these.This is an old SM75-150 with the straight waveguide, it can be even more than 40 years old.
It is not available but when it was they were about $700 each or so.How much is the driver new ?View attachment 380446
Newest version appear to be £1025 each inc. VAT, according to the most recent price list I can find online (2021)SM75-150S
Is the newest version ?
There was always SM75-150 non-S and S versions, the main difference is the magnet size and it's effect. The S version have a larger magnet, so the drive is stronger, the sensitivity/efficiency is higher.SM75-150S
The S version has a higher Bl product because of the more powerful magnet, and that affects the other t/s parameters (and FR). The S has a bit better HF linearity.There was always SM75-150 non-S and S versions, the main difference is the magnet size and it's effect. The S version have a larger magnet, so the drive is stronger, the sensitivity/efficiency is higher.
Also there is probably some difference in the suspension.
Well, good to know it's a water based dope.This is why you should never clean the ATC woofer's diaphragm with water, it dissolves the coating (/facepalm):
https://avxforum.hu/forum/viewtopic.php?p=2887101#p2887101
Is it OK to clean it with a different material ?This is why you should never clean the ATC woofer's diaphragm with water, it dissolves the coating (/facepalm):
