BatsEar, I don't know that damping product and probably shouldn't give advice as I only know enough to be dangerous. The product I used has a single heavy layer on the adhesive side, tar or rubber like, and about an inch of dense foam on top of that. It added a few pounds to an already heavy speaker. According to the website I bought it from, you don't want a suspended heavier layer above the cabinet mounting surface as it will "mass load" the woofer. I have no idea whether that's true or not or makes a sonic difference.
I also hesitated damping this cabinet for a long time as I was afraid of changing the sonic character significantly. I'm a lay person, but I understand that proper speaker design, aiming at as flat a response as possible, requires multiple factors in controlling and working with cabinet and driver rsonances. (It's possible I have tin ears and just screwed up the entire response curve and don't realize it!) I doubt that very much, but it would be interesting to know for sure. I will consider sending this to Amir but pretty hesitant as audio gear is one of my prized possessions. (Like all of us here)
I wouldn't say the change is transformational, but my impression is that taming the cabinet made for a flatter speaker, and it definitely improved its interaction with the room. But, that's just my humble opinion without empirical data.
I'd be curious from those better informed than I, that if by adding additional damping to a commercially designed cabinet, whether there's a chance you can alter the FR in a negative way? Is more damping usually better, or not necessarily?
Cheers
Cheers
