I've spent quite a bit of time searching for detailed information and decent photos of the amp packs used in the ATC SCM150ASL Pro. There are plenty of pictures out there, but most are too blurry or lack the detail I was looking for. Eventually, I decided there was only one thing left to do: open it up myself.
Fortunately, disassembly is very straightforward. The only things worth mentioning are that the mounting holes are surprisingly shallow, and the power transformer is seriously heavy. When removing the last two screws, make sure you have a firm grip on the handle beforehand. You don't want that transformer suddenly dropping on you!
After opening it up, I have to admit I was a little disappointed.
1. The XLR input wiring and grounding
The XLR cable is surprisingly thin. It travels a long way across the chassis before reaching the top of the PCB, right at the low-level input section. Interestingly, the PCB actually has a dedicated grounding point, but the ground wire is connected to ground right at the input connector instead. Perhaps the designer changed their mind after the PCB layout was completed and decided that grounding it locally would be a better solution. Who knows? There may well be a good engineering reason for this.
2. The power transformer
The transformer has absolutely no shielding. It appears to be an OEM-sourced unit, yet there are no visible manufacturer markings or specifications on it. I would have expected at least some identification or rating information.
3. The six audio output wires and connectors
There are six audio wires feeding the three drivers. The total amplifier output is supposedly around 300 W, but frankly, the connector and wiring don't look particularly convincing for that kind of power. They certainly don't resemble anything you would associate with fancy audiophile cabling. I don't actually believe the wires are a bottleneck here. However, that black six-pin connector is seriously testing my audiophile imagination (or perhaps my expectation bias). And guess what? The connector pins appear to be aluminium alloy rather than copper. The six wires are also packed very tightly together. It almost looks as though someone was worried that separating them would make the connector difficult to plug and unplug!
4. Signal wiring running close to the mains section
The audio wiring happens to run right alongside the mains power section. It doesn't look particularly reassuring from a layout perspective. That said, I have to give ATC credit where it is due: I have never heard any audible hum or noise, even with my ears just 20 cm away from the speakers. I previously reduced the input sensitivity to 1 V, simply because I have never needed more gain. My DAC's digital volume control normally sits at around -30 dB anyway. So, whatever the theoretical concerns, the actual noise performance seems perfectly fine.
5. Mains wiring and components
I have no particular concerns about the actual power cable's ability to deliver the required current. However, the rocker switch, fuse holder and power distribution block all look rather inexpensive. The wiring itself is also quite thin. I was previously wondering whether it would be worth upgrading my 10 A-rated IEC power cable. After seeing this, I think I'll save my money.
6. Capacitors
Pretty much all the capacitors, large and small, look like ordinary budget-grade components. Nothing particularly exotic or remotely audiophile-looking.
But honestly, I don't think they necessarily need to be. I have no reason to doubt that more expensive capacitors would make things audible better.
7. Those blue trimmer potentiometers
I really don't understand why ATC chose these old-fashioned blue trimmer potentiometers with white plastic adjustment screws. I've built electronic circuits myself decades ago, and I remember using better-looking components even back then. There are plenty of inexpensive, modern alternatives available today. My main concern is the white plastic adjustment mechanism. It doesn't inspire much confidence in terms of long-term mechanical durability or adjustment precision, especially if it is turned repeatedly. The small adjustment holes on the amp pack, provided for bass level and input sensitivity adjustments, line up exactly with these potentiometers. It's quite a contrast: solid mechanical construction on the outside, rather dated components on the inside.
8. The enclosure
The entire amp pack is installed inside a sealed compartment. There is actually a reasonable amount of space in there, so it isn't particularly cramped. I haven't investigated the thermal design in detail, but the enclosed arrangement is certainly worth noting.
9. The NE5532 op-amps
And here we have the legendary NE5532! An op-amp that was once regarded as the king of audio op-amps several decades ago is still sitting there in large numbers.
There are quite a few NE5532s on the board. I assume most of them are used for crossover filtering and signal conditioning. I sincerely hope they are not directly involved in the main amplification stages, particularly the high-frequency amplification. I say this because I once replaced an NE5532 in another DAC, which was also around 30 years old, with an OPA1612. The improvement I perceived was remarkable. It was almost like listening to a completely different DAC.
Of course, that was a subjective listening impression, not a controlled measurement. But it certainly left an impression on me!
But,
I genuinely believe the people at ATC know what they are doing. They are professional engineers, and whatever my observations about the components and construction, I still thoroughly enjoy listening to my ATC speakers. Perhaps this whole exercise is a good reminder of something we audiophiles don't always like to admit:
When we spend money on Hi-Fi equipment, perhaps 90% of what we are really paying for is our own subjective experience — including our expectations, our lack of technical knowledge, and occasionally our own illusions. And that's perfectly fine. As long as you enjoy, who cares? Happy listening!
