When someone writes something like that, IMO their credibility reduces to zero. Everything that follows is probably in their imagination. If metal jumpers affect the sound audibly (in a way that resembles the aesthetic qualities of the component!), then all the other blather about coils, motors, frames, chassis, etc. is pointless. Clearly in this person's mind, a component's specification and design is meaningless if something as simple as an electrical link can impart an audible change, so why even state factual information about these things?... the sound was impressive, dynamic and powerful, with a desirably fast and crisp bass, but also with a mild and somewhat detached ‘chromium’ sheen to the upper treble. Deleting the supplied metal terminal jumpers and substituting bare wires fixed the sheen
OTOH, my interest in what they have to say about the sound picks up ... an inconvenient truth about audio is that a chain is only as strong as the weakest link, and if a piece of cheap metal happens to be the latter, then the most incredible magnet structure in the world is not going to make it better ..When someone writes something like that, IMO their credibility reduces to zero. Everything that follows is probably in their imagination. If metal jumpers affect the sound audibly (in a way that resembles the aesthetic qualities of the component!), then all the other blather about coils, motors, frames, chassis, etc. is pointless. Clearly in this person's mind, a component's specification and design is meaningless if something as simple as an electrical link can impart an audible change, so why even state factual information about these things?
(I was once granted an audience with said person!)
Poor quality electrical links do add a "detached ‘chromium’ sheen" to the sound
Are there any published reports that address this "detached chromium sheen"?
There's a whole industry that deals with the behaviour of electrical contacts in the real world - the guru here is Ragnar Holm, the bible is "Electrical Contacts - Theory and Application" ... unfortunately, bare metal to metal contacts are rather unpleasant things, if you want to guarantee integrity of that interface - it gets very complex, very fast.Are there any published reports that address this "detached chromium sheen"?
Poor quality electrical links do add a "detached ‘chromium’ sheen" to the sound, and the better the rest of everything, the more pronounced that weakness will be, subjectively - would you drive a Ferrari using the cheapest wheel nuts one could buy from a bargain store?
This is all I could find at the moment...
They are directional above 5khz. That’s what you’d expect from ATC. I bet they are dark sounding in most normal rooms.
Look at the lateral off axis measurements in the Hifi critic. The SPL off axis drops like a rock at all frequencies higher than 5khz compared to on axis. I’m not sure what the best word to describe the sound would be. Be it’s not ideal performance for a modern high end speaker.What is «dark sounding»? Exaggeration of lower frequencies (than 5khz)?
The obessesion with real or imagined "audiophile" reasoning flaws always surprizes me. As if anything wrt biased or flawed resoning would be exclusive to "audiophiles".....
Real world experience showed me that multiple terminals on a somewhat rigid connection piece of metal can be a real pita wrt reliable (means pure and low ohmic connections) even when fastend with constant torque tools. Edit: Clarification; means when terminals mounted on rigid plate and an additional connection via a quite rigid piece of metal is made,
Given that Colloms also mentioned his difficulties to get reliable/repeatable resistance numbers on those metallic strips, is it really out of reason that there might exist some compromising impact??
Beside that, is "cromium sheen" soundwise really associated with plating of "dark grey" colour?
At least i undertood your remark as a hint that a "shrill" sonic impression is associated with the "shiny" look of the interconnection, which in this case wasn´t - according to Collom´s description - metallic bright...
How would you suggest that be done?There is no mystery in metal to metal connections and their integrity can be measured, as can any compromising affect on signals.
