Do you just been a power amp for each, meaning you have a preamp already? If so the Topping PA5 good for a small room. The ATC are lower on the sensitivity side at 85db, and a 6ohm average through must of the frequency but shouldn't be an issue. Couldn't find any review info of the Classic.anyone can help?
ya.. i have 2 dac, K9pro ess and Ares II so no prob for preamp.. u mean PA5 can drive ATC 11?Do you just been a power amp for each, meaning you have a preamp already? If so the Topping PA5 good for a small room. The ATC are lower on the sensitivity side at 85db, and a 6ohm average through must of the frequency but shouldn't be an issue. Couldn't find any review info of the Classic.
In a small room sitting 3 meters away you need 45 watts and 3db headroom.ya.. i 2 dac, K9pro ess and Ares II so no prob for preamp.. u mean PA5 can drive ATC 11?
may i ask what naim amp u talking about? thanks for the reply =)ATC cones aren't the lightest, they're generally very tautly suspended and they really do seem to need the extra 'push' of a higher powered amp. Having said that, I did hear a pair of 11's Naim driven to fair domestic volume levels and smaller Naim amps are to me, hard clippers which HURT when pushed too far.. The 11 has a 'flatter' bass to mid balance than the 19 or 20 generally, so not as anaemic sounding if under-driven.
The smaller and streaming models primarily. The other larger power amps have a touch more headroom even if the power per channel doesn't seem much greater. If you own a Naim amp and a well recorded singer doesn't make you wince when they 'sing out,' then you've nowt to worry about Maybe in a dem situation I like to turn it up a bit...may i ask what naim amp u talking about? thanks for the reply =)
ok thxIn a small room sitting 3 meters away you need 45 watts and 3db headroom.
thx man i will take look on that amp.Take this so you do not have to think about whether you have enough power:
Amir:
"As such, I can recommend the A800 as an everyday amplifier."
Behringer A800 Stereo Amplifier Review
This is a review and detailed measurements of the Behringer A800 Class D Stereo Amplifier. It is on kind loan from a member. The A800 costs US $299 including free shipping from multiple sites. The member who loaned it me has done a youtube video of it which you can see by clicking on this...audiosciencereview.com
That A800 actually has more power than you need per se, but you can still think of that amplifier, as an alternative.
Edit:
A800, not as good SINAD (77), as Topping PA5 (106), which was mentioned by Everett T, but then reality comes in to pay. What is audible, regarding SINAD?
