AT LP60X buzzing when connected to amplifier
lines1
Hello everyone,
So I recently bought a Fosi BT10A amplifier to use my new speakers with my LP60X. Previously, I had my turntable connected to some active speakers using a male to male 3.5 cable and everything worked perfectly, no buzzing. Now, however, when the tt is connected to the amplifier using the same connection, buzzing can be heard. When I go to play a record, the buzzing stops immediately once the platter starts spinning. When the record finishes, the buzzing starts again. I've tried 4 different cables and the problem's persisted across all 4. However, I've found that the buzzing is slightly less noticeable when I use the initial cable I've always been using that has a silver tip and a completely flat bottom. The buzzing remains even when the tt is disconnected from power and I've moved the tt around and away from other electrical devices, still, it buzzes. If I turn the volume down on the amplifier, the buzzing becomes quieter and vice versa when louder. The amplifier works perfectly with my PC that I have connected through my DAC. I'm slowly starting to lose my mind here so any help would be much appreciated :)
