This is a review and detailed measurements of the Astell&Kern Kann Ultra DAP. It is on kind loan from a member and is on sale for US $1,499.
Forget any notion you have of a smartphone. This thing looks like one but is far, far heavier and thicker. Machining has left sharp corners which are unkind on fingers. The rotary volume control is slow and the display for it does not keep up.
On positive front it has wifi streaming including support for Roon! Didn't see that coming from a portable player. I tested both Roon streaming and playback using its USB-C cable. Yes I know, many will use an SD card with it but performance should be the same.
There are a set of balanced and unbalanced connections for Line and Headphone out:
As you see, labels are hard to read. The heavy weight of the unit comes in handy when using it on the desktop.
Astell&Kern Kann Ultra Measurements
Let's start with line out at max volume using balanced output:
This is impressively good for a DAP! Distortion is inaudible and noise floor is good. Both suffer though with unbalanced output:
Measuring noise by itself, it turns in very nice numbers, almost approaching dedicated desktop products:
There are selectable filters; I chose the fast linear which resulted in nice frequency response:
Linearity is as it should be:
Story becomes less good when we look at IMD distortion:
Jitter seems unsightly, though inaudible:
Multitone shows raised noise floor at lower frequencies:
That is a clue to issues there when we run distortion vs frequency:
To save my sanity, I only tested balanced headphone out, starting with 300 ohm load:
While we have plenty of power in max "Super" setting, there is much elevated noise. Even more strange is very limited power at 32 ohm:
We can see the strangeness in full exposition when we sweep impedances using high gain:
This is not how it should be for a device that is very focused on headphone output.
The Kann Ultra starts strong, turning in very good noise and distortion numbers as a DAC using balanced output. From there though, cracks in the foundation is seen, culminating in a headphone stage that is very poorly designed when it comes to gain management and low impedance loads. It should however be good if you use high impedance headphones.
Overall, this seems like partial improvement. And partial improvement is not what want to see in a device that costs $1,500.
I can't recommend the Astell & Kern Kann Ultra DAP.
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
