Marc v E
The Netherlands (Holland)
@Racheski @amirm : would you consider adding a threshold of hearing/transparancy line in the graphs?
That knowledge helped me a lot in understanding what is money well spend. I notice it is a recurring thing in threads that comment on reviews.
somebodyelse
Thanks to all involved - it's a definite improvement.
One oddity I noticed - for Type 'ADC/DAC Interface' and Channels 'Multichannel' only the MOTU 624 shows up. Others I would expect to see like the 18i8, M4 and Xonar don't.
I propose adding 'balanced' as a tag too, since it crops up in people's requirements from time to time.
What are the requirements for data entry? I may be able to help with the above.
pozz
Слава Україні
Editor
pozz
Слава Україні
Editor
The threshold of transparency depends on playback level and system setup, gain structure.
There's a thread by @flipflop that has lenient and strict thresholds: https://www.audiosciencereview.com/...-thresholds-of-amp-and-dac-measurements.5734/
If you want to take psychoacoustic masking into account it gets a lot more complicated.
ahl
For Gr research xls encore include the price of a complete finished speaker rather than only price of kit for a realistic price. Thats 269 (kit) + 500 (finished cabinets from Gr research ). 385 per speaker.
pozz
Слава Україні
Editor
Thanks.
eyeral
hello, how can i solve this problem with this page showing? eyeg
pozz
Слава Україні
Editor
I think it's an issue on your side. No problem loading the review pages on my computer or phone.
pozz
Слава Україні
Editor
For the Infinity 253 tower, Amir changed his recommendation to a Yes after learning about his amp failure. So not sure who needs to change that.
Will fix.
Jbrunwa
Seattle
If the numbers in the review indexes are correct, Amir has conducted nearly 1,000 reviews!
772 electronics
166 speakers
057 headphones
995 total reviews
Semla
772 electronics
166 speakers
057 headphones
995 total reviews
He passed that milestone somewhere in July - data entry is lagging a bit behind.
pozz
Слава Україні
Editor
Vincent Kars
Little snafu, the table says RME ADI-2 Pro but the link points to the Lynx HiLo
pozz
Слава Україні
Editor
No, it's correct. Scroll down to find comparative measurements of the RME. In Amir's old review format he would often do on the spot comparisons with other devices.
pozz
Слава Україні
Editor
for some reason the index cannot be viewed on iOS (iPad/iPhone) ?
No problem viewing on iPad, Macbook or iPhone here.
Vincent Kars
I see, thanks
Dennis_FL
The KEF LS50 metas are missing from the database.
Also...I remember seeing the music tracts amir uses to subjectively rate speakers but now I can't find it. Anyone remember which review that was in?
