What do you think the extra Purifies would do? But you don't really need a lot of volume for the Daytons, you can always DSP them.I'm not sure I quite follow, wouldn't larger (yet along multiple) woofers increase the Air volume requirement of the cabinet considerably making it already significantly larger?
That is below -45dB above 100Hz, which is below 0.18%
Sure it will have much better bass extension and low-end SPL, but midrange performance is on par with the Kef which is the same price fully finished and build, only one stereo amp is needed
Edit: as @Sancus noted, I was about 10 dB off, so the Kef is not on par with the Purify, but it's not that far off either. Still quite impressive for what you get for the money though.
What have I been smoking then? Because when I put in the numbers something else came out. You are absolutely right
