VQR
- Joined
- Oct 15, 2021
- Messages
- 148
- Likes
- 351
It's tough sometimes holding back my inner millenial troll.I'm banned on both btw, and i don't mind at all.![]()
Good work!I'm banned on both btw, and i don't mind at all.![]()
I've also got to school myself on Op amp selection.
www.audiosciencereview.com
I don't bother with that sort of stuff. I have in the past when young but now I consider it silly and a waste of time and energy that I can use doing productive things. I'm not a good troll anyway...LoL.It's tough sometimes holding back my inner millenial troll.![]()
I don't know your background, but I grew up trolling online. I'm dating myself with that comment of course. I can be good at trolling if needed.I don't bother with that sort of stuff. I have in the past when young but now I consider it silly and a waste of time and energy that I can use doing productive things. I'm not a good troll anyway...LoL.![]()
My first 3 pooders starting at a P75 I think it was where for gaming and IRC as a OP. So I had no time for trolling LoL. It was chat, chat, chat and a bit of OPing as required.I don't know your background, but I grew up trolling online. I'm dating myself with that comment of course. I can be good at trolling if needed.![]()
The choices for this Apollon purifi are Opa 1612, Sonic Imagery 994 Discrete and Sparks SS 2590 Pro. From least to most expensive. I guessing the Opa 1612 for no additional charge is the common choice. I haven't the slightest idea.
I was not trolling, just telling facts with proof that they didn't like....It's tough sometimes holding back my inner millenial troll.![]()
Now that’s a novel way of beating the Dating scene.I'm dating myself
I will. That's my plan. I try to keep a realistic approach as in whether I can hear the difference. Why pay for upgrades I can't use.Have you downloaded the data sheets for these OP amps and compare them?
Yes, and there is a ton of information in those data sheets that is transferable and some shows the differences or not between the Op amps. Usually the original design is a mix of what is economically applicable and what is the best performance and has the right circuit parameters for the final design of the OP amp circuit. Then the designer chooses the feedback and gain and calculates the proper peripheral components for the topography. So... Sometimes swapping a OP amp may change the sound but that does not mean it is better.I will. That's my plan. I try to keep a realistic approach as in whether I can hear the difference. Why pay for upgrades I can't use.
Yes, they are very different. One is the resistance of the output feed going to the OP amp's input and the other the resistance of the OP amp input. To have a very low output resistance is good and to have a high input resistance is good. So it's low to high is the best choice for audio applications. If other applications this may change.Ok I need help with this one. Under "Noise Performance " in the OPA 1612 data sheet it states, " The low voltage noise of the OPA 161x series op amps make them a good choice for use in applications where the source impedance is less than 1k ohm."
The Purifi stats states, "High Input Impedance 100K."
Are these different impedances?
Amir?
I thought it must be considering the large delta.Yes, they are very different. One is the resistance of the output feed going to the OP amp's input and the other the resistance of the OP amp input. To have a very low output resistance is good and to have a high input resistance is good. So it's low to high is the best choice for audio applications. If other applications this may change.
Usually for audio applications look for at the least a 1:10 ratio between output R and input R. It's very common to use this general rule or to better it.I thought it must be considering the large delta.
Thank you for the lesson. Now back to it.
So 100:1 definitely betters it.Usually for audio applications look for at the least a 1:10 ratio between output R and input R. It's very common to use this general rule or to better it.
O' yeah that's a fine ratio to have. Keep in mind the feedback network which can be a resistor, a inductor, a capacitor or all three of them or more is effective at circuit changes gain and such too. So with keeping those feedback elements in mind the gain across the hearing spectrum is sometimes changed and the OP amp that is used in circuit has been calculated for optimal operation and expense. So I suggest looking at the gain specs for each OP amp (At the beginning of the data/spec sheet.) that is to be rolled and then you can see if one has more gain than the other(s). The gain is really what is occurring when rolling OP amps because they all have such a good slew rate that the rise time and resulting frequency response exceeds the needs of the audio circuit and so a gain difference is sensed as louder and better.So 100:1 definitely betters it.
Good choice.I'm leaning towards going with the standard Opa 1611.
