Keith_W
- Thread Starter
- #101
Hello @Keith_W and everyone,
I have used Acourate quite a few times with Roon, but yesterday I went to edit the target curve in an existing project, run again macros 0-5 and the resulting convolution filter when imported to Roon produced a highly distorted loud sound that was clipping with a -10dB headroom. I have attached the relevant files.
Unfortunately, I can not open the "Acourate4Roon" zipped folder. This is what you need to do to find out what is going on: open Cor1 to CorN in Acourate and examine them:
The highest point of each XO should not exceed 0dB. If it exceeds 0dB, you could try to manually fix it by using FD-Functions - Magnitude Normalization, select all the curves you wish to normalize, and choose "Groupwise". Save all the curves.
(EDIT): I should point out that you need to compare left and right filters before you do this. You might note that in my set of XO's, the filters do not reach 0dB. This is because these are all left sided filters. There is ONE filter on the right that reaches 0dB, and the rest of the filters are automatically normalized by Acourate to that filter. If you simply normalized one channel without considering the other, you may create a channel imbalance.
Otherwise, you made a wrong setting in one of the room Macros, most likely Macro 4 (make sure Max Correction Gain is set at 0dB).
If your filters do not exceed 0dB, then the problem might be the way you loaded the filters into Roon.
PS Playback chain is Wiim Pro (Tos link @ 24-bit 192Khz) ---> miniDSP Flex --> power amp
Strange playback chain. You send 2ch output from Roon into the Wiim, then you apply DSP again with the MiniDSP?
