Keith_W
- Thread Starter
- #61
Comparisons with DSPNexus?
DSPNexus is a fundamentally different DSP product. It's a hardware DSP unit. You need to design filters for it with filter design software. In the case of DSPNexus, they use Audio Weaver. DSPNexus uses 5th generation SHARC chips which use minimum-phase IIR filtering with a limited number of FIR taps. Competitors for the DSPNexus would include things like MiniDSP, Xilica processors, and so on.
Acourate is FIR filter design software which makes FIR filters. These can be linear phase or minimum phase, but most Acourate users make linear phase filters. The filters have to be loaded into a software convolver (this is a separate purchase, but if you use JRiver or Roon, you already have a convolver). This can be PC based, run on a headless SBC, or something like a Raspberry Pi. Competitors for Acourate are the other FIR filter design software packages, e.g. Audiolense, Focus Fidelity, Eclipse Audio's FIR Designer, etc.
A hardware DSP unit is better if you want to connect external sources for DSP because they usually have ADC's and digital inputs built-in. Whilst it is possible to run a phono stage through the ADC of your interface and route it through your software convolver, the process isn't as convenient or as seamless as it should be. On a MiniDSP (and maybe on a DSPN?), you press a button on a remote and you switch inputs. With software based DSP, you have to dive into your convolver's settings and change the signal routing. The real advantage of software based DSP is the virtually unlimited CPU power which lets you have thousands of FIR taps with very high sampling rates - up to 262,144 taps at 384kHz with Acourate.
Please read this thread: Understanding the state of the DSP Market for more info.
While this may be a bit off topic, one expert on DAC design at diyaudio.com, though unable to gain access to the DSPNexus's clocking, output stage, power supply schematics or at least looks at the pc boards, said that based on its top optional model AKM DAC chips the DSPN is a better value than the Merging Hapi for a multichannel DAC.
"Better value than a Merging Hapi" depends on your point of view. If all you need is 8 DAC channels, then of course the Merging Hapi is a very poor value proposition since it is so expensive. But if you need dozens of DAC channels, virtually unlimited expandability, a really robust system to tie all your devices together ... then it's hard to argue against Merging. Well, you could use Dante enabled devices which provide the same functionality, but they aren't much cheaper than Merging.
You don't have to use a Merging Hapi if you use Acourate though. Any multichannel DAC will do the job, as long as it has ASIO support. This includes things like Motu, RME, Lynx Hilo, Focusrite, and other pro audio interfaces.
In any case. my concern is that even if I hire Hollis Labs (as Danville's Al Clark advised) to remotely control my pc and guide me through making the live test tone measurements for them to build the software based crossovers, is the DSPNexus still the right solution to use for biamping my three-way speakers, either for semi noobs like me or expert users? That is, might the learning curve be substantially less with which other such 2 in/8 out box (es) or other processors?
All DIY DSP products have a learning curve, but some software is easier to learn than others. Audio Weaver does not look easy to learn, but it does look like an incredibly powerful tool with a lot of options that will confuse you (if you are a beginner) or delight you (if you are a DSP nerd). BTW I suggest you check their licensing, I think it's a subscription based software package with annual license required. Acourate is one off payment with lifetime license, but there are periodic upgrades, and if you want those upgrades you have to pay. Audiolense is the same.
