I played with this in my Flex HTx setup. OCA’s 0.707 / 0.577 were great starting points, in my room the broad issue around 44 Hz measured best with Q0.5 on the right sub.
After that I still had a smaller weakness around the upper-50s, so I added a second AP at 56 Hz Q2.0. My thinking was the first AP was a broad low-bass phase correction, while the second needed to be more localized since it was closer to the main/sub overlap region.
With the APs off, the 25–45 Hz region loses a lot of foundation. With them on, low-bass summation comes back while the 60–100 Hz region stays mostly intact.
Acourate looks powerful, but for HDMI/movie use with the Flex HTx, I think I’m mostly limited to IIR/biquad tools unless I move processing upstream to a PC/convolver. The important thing I learned was lot of trial and error because applying the same AP filter to different sub one at a time creates different results. I'm still learning / experimenting.
Before two all pass filters no other changes to delay, crossover, PEQ
After just AP 44hz Q.5 and 56Hz Q2.0
