Ashly NE8250 Review (Pro 8-channel Amp)
Rate this amplifier:
    Votes: 152 89.9%
    Votes: 9 5.3%
    Votes: 7 4.1%
    Votes: 1 0.6%
This is a review and detailed measurements of the Ashly NE8250 professional 8-channel networked power amplifier. It is on kind loan from a member and costs US $2,386.
The look and controls are fine. It is going in a rack after all. Note that back connections are all phoenix blocks:
You can make your own cables or buy adapters (I made mine). There is a nice network UI interface and app.
Ashly NE8250 Measurements
All measurements are from channels 3 and 4. Let's start with our dashboard:
That is huge amount of harmonic distortion, placing the amp almost at the bottom of our SINAD list:
Strangely, in a good way, noise floor is low:
Frequency response droops at either end but surprisingly it is not load dependent despite being Class D design:
Ashly NE8250 Measurements Frequency Response Professional 8 channel Amplifier.png
Crosstalk is fine:
Multitone shows poor performance that we would expect:
You buy these amps for power so let's see how it does at 4 ohm:
Ouch! That distortion curve is crazy. It almost act like a tube amp or something! Distortion is so high when it clips that when we measure at 1%, we actually get less power:
Ashly NE8250 Measurements Max and Peak Power 4 ohm Professional 8 channel Amplifier.png
Switching to 8 ohm doesn't help:
Sweeping the frequencies we see this pronounced hump:
Ashly NE8250 Measurements Frequency vs distortion vs Power 4 ohm Professional 8 channel Amplif...png
So my guess is that it is a class G design but company says Class D.
The distortion in this amplifier is just out of control. It is also not every powerful on a per channel basis. So I don't see it having a good application for home use in either main or sub amplifier. It is also expensive so I don't see the value in it either. Then again the owner said they come up much cheaper on ebay so maybe that would be some motivation to buy it.
I can't recommend the Ashly NE8250. Your ears deserve better!
Edit: video review posted:
I'm kind of sorry to see one of my prejudices confirmed: "don't buy exotic hardware"...
Only positive thing about this:
It's working according to published specs.
They say 150W/channel under 8 ohm and 250W under 4 ohm.
And SMPTE IMD 0,5% at -10dB vs full power, which I guess is realistic.
Meager consolation, I know.
The year has just begun and there can be even worse ... here it puts in place those who swear by professional equipment as opposed to "hifi" without having seen the measures..
Distortion factory.
If you need this exact feature set in 2HE space, look at the Lab Gruppen C20:8X. I've seen one go for 800USD used on ebay, which is a killer deal.
Nothing exotic about Ashly, brand has been around for years. It's just a typical PA amplifier for fixed installs, with expected performance.
Really? Where I live (Germany), I've never even heard the name before.
/edit: Out of curiosity, I've entered it @ major pro gear shop here, Thomann:
Crosstalk is fine:
so its a cat litter amplifier . is the graphs of each channel output as they are not overlapping . i assume the rubbish harman international crown cts8200 i have if i did frequency sweep of each 8 channels i won't see an overlap as harman crown amps i think they rubbish . at least i got mine cheap as i they certainly ain't worth the retail price . i think harman engineers are overpaid rated and lazy , because they can't align 8 channel amp so when a sine wave tone 1KHz is generated i should see equal levels on the input and output and it is a mess i have to align all the channels myself because harman are lazy , never buy a garbage harman anymore and certainly not this amplifier
i would gladly throw the harman cts into the cat litter also they are s/n ratio noisy i think harman are hard of hearing or blind to see the noisy noise of their lazy work on an oscilloscope
That back panel deserves an award of its own.
Has anyone ever seen anything so tacky on an amp over £10?
A lot of amps designed for fixed installations use euroblock connectors.
I own a few pieces of older Ashly signal processing equipment (parametric, graphic eqs) and they are well made and perform well.
Edit: Here are the published specs:
I would love to see some Linea Research/Danley amps tested. They have very impressive specs on paper.
Yikes that thing looks broken. By chance was that amp purchased used off ebay?
If it was purchased new and is not meeting spec it should be sent in for repair.
sent to me so i can cat litter it
It is a PA amp.
They are Phoenix connectors and are common there in pro land and they are deff preferred by some.
Well to be fair, I bet it measures better then quite a few tube amps will and is 8 channels with way more power than typical tube rigs.
I think in a home theater these would be fine. Not what I would buy now but if it was already installed then I'd leave it there.
I have used Crown amps and they sound as good as anything else I have tried, esp if you want power and a warranty for a fairly cheap price.
In any case this is an 8 channel, single chassis PA amp, it is totally fine for that.
But yah ultimately I agree, better wait for the test result before commiting pro amps to audiophile use.
Picture it in a church, school gym, budget dance school, bar, meeting space/convention center.. ECT.
Looks pretty much right on for the specs -> http://ashly.com/wp-content/uploads/2015/08/ne-multi-channel-amps-black-r07.pdf.
150 W in to 8 ohm and 250 W in to 4 ohm both with 1% THD (not THD+N or SINAD). Looks about right from the review.
THD+N at 0.5% (46 SINAD) at 10 dB below full power (15 W) in to 8 ohm. Review shows better than 60 dB SINAD at this level so better than spec.
105 dB SNR, 20 - 20K, unweighted at 105 dB. Review has 107 dB SNR at full power, so beats this by just a bit.
Michael
