Ashly FX125.4 Multichannel Amp Review
Rate this amplifier:
    Votes: 7 5.3%
    Votes: 25 19.1%
    Votes: 88 67.2%
    Votes: 11 8.4%
This is a review and detailed measurements of the Ashly FX125.4 4-channel DSP amplifier with network control. It was kindly drop shipped by a member and costs US $999.
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier spdif digital review.jpg
As you see, this is a very compact enclosure for a 4-channel amplifier. I liked the indicators in the front but wished there was a power button and a reset either on the front or back:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier spdif digital back pa...jpg
Both analog and digital inputs and output for the latter are provided. There is a fan internally but it only came on when I pushed it to max power.
With no buttons to control routing/inputs I connected an Ethernet cable to the unit only to find out that it is set to static IP address. :( What this means is that if you want to talk to it using that wired interface you would have to set your computer to a static IP in the same class. This should have instead been DHCP so that it would land on the same network as your control computer. Fortunately there is also Wifi with AP support so I connected to it to change the settings.
Once there, the user interface on the network was rich/responsive and other than routing/gain, was rather easy to navigate.
Commercial amplifiers tend to perform worse than average than consumer ones. Will the Ashly be the same? Let's find out.
Ashly FX125.4 Amplifier Measurements
I performed all of my testing in stere using Channels 1 and 2. Let's start with RCA analog input after setting the internal gain to 25 dB:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced measur...png
Combination of noise and distortion as represented by SINAD is quite good for class an exceeds the average for all amplifiers tested:
We must be limited by amplifier performance with a DAC that is superior to it as S/PDIF did not improve things:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier spdif digital measure...png
So for remaining tests, unless said otherwise, I will be using RCA input so results are comparable to other amplifiers tested. To that end, here are the results of me turning on the DSP and setting one channel speaker profile to be high passed at 80 Hz:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced High P...png
As you see, there is no impact on performance overall. A delay is caused however (see shifted sine wave) so you would have to accommodate this if only apply processing to one channel and not the other.
Frequency response shows almost no load dependency but with an ADC digitizing around 44.1/48 kHz:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced freque...png
I was hoping that digital input would provide wider bandwidth. But it did not despite me using sample rate of 192 kHz:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier spdif digital frequen...png
It does produce flatter bass response however.
Signal to noise ratio is very good for professional class amplifier:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced SNR me...png
And channel separation quite exceptional regardless of class:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced SNR ch...png
Was surprised to see this in such a compact enclosure.
Multitone again shows respectable results for a Pro amp:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced Multit...png
There is class rise in distortion with frequency which does hurt 19+20 kHz intermodulation test results:
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced 19 20 ...png
We are able to get close to rated power (125 watts per channel):
Ashely FX125.4 4 channel networked DSP professional pro stereo amplifier RCA unbalanced Power ...png
Naturally less with 8 ohm load:
I could not run my 40 Hz or max and peak power due to that super sharp clipping. Distortion would go from 0.02% to 2 to 9% with slightest adjustment of input. My tests require 1% THD and I just could not get there. The amp is either clean or heavily distorted at the limit. There is a limited which I turned off for testing. It may have been put there for this reason.
My power sweep relative to frequency seems to imply we have a class AB amplifier here with a switching power supply:
So very well behaved.
I went into this review with the mindset of a commercial amp producing sub-par performance. By the time I suffered through controlling it through network connection, I was so sure the 125.4 was going to underperform. That changed in test after test showing competent and class leading performance relative to its peers. DSP and routing capabilities are extensive making this an ideal amp for driving say, two active 2-way speakers (there are even settings in there specific to each driver). The fan can be a nuisance if you push it hard in which case, you may want to go up int he model to get more power.
I am going to recommend the Ashly FX125.4. Nice to see them going above and beyond for a market which seems to only care about features, size and power rating.
Specs:
• Offers high power density:
  • 60W or 125W by 2 or 4 channels in ½ RU chassis
  • 60W or 125W by 8 channels in 1RU chassis
  • 500W or 750W by 2, 4, or 8 channels in 2 RU chassis
• Low (2*/4/8 Ohm) or Hi Impedance (70/100V) operation, selectable in software
• Balanced Mic/Line inputs on removeable Euroblock connectors, plus unbalanced RCA inputs
• 2-channel SPDIF Digital IO
• Front panel status LEDs for amp, Input, output & network
• Advanced Dynamic Power Sharing distributes power between channels, with up to 4x channel power**
• Networkable via Ethernet or built-in WiFi
• Built-in advanced DSP on all inputs & outputs, including: Sensitivity, Routing, Gain, PEQ, Compressor, Limiter, FIR Filters, X-Over, Polarity & Delay
• Browser-based UI accessed via PC or mobile device. No software to install.
• All models have 4 Input channels x 2, 4, or 8 Output channels. (8 inputs on 8 channel models)
• Auto/Manual Power Saver Mode (sleep/standby), adjustable in Software
• Customized Speaker Presets made be created, saved & loaded for each output channel
• Addressable GPIO, Standby/Mute & VC remote ports. VC assignable per channel via software
• ½ RU models easy to hide in “non-rack” installations.
• Highly efficient Class D and lightweight
• Optional hardware for ½ RU models for rack & wall/surface mounting.
Looks like there are balanced inputs. Did you measure them ?
Should have 2x250W in Stereo too.
(EDIT: seems to be for 70/100V output only)
Interesting one, thanks for the testing Amir.
Slight error in the title though, missing the "S" in Ashly. :)
The FX series is a range of multi-purpose installation DSP-equipped amplifiers. The FX series amplifiers feature a built-in Wireless-Access-Point (WAP) for simple connection and configuration via WiFi as a well as an intuitive web-based software UI.
No pics on this one, however apparently the Ashly FX125.4 amplifier uses a proprietary Class D module developed in-house by Ashly... can anyone confirm this?
JSmith
It has that. The problem is that it ships with DHCP disabled.
Is that maybe for the typical commercial user? Would they probably not want a fixed IP address in that environment? I'm probably talking tosh but from my limited knowledge that seems to be the case in commercial IT Networks...
This is completely normal for commercial/installed/professional/live audio systems, especially when they live on networks that use IP audio protocols (Dante, AVB/Milan).
Relying on DHCP can wreak absolute havoc on installed systems, especially if after a power interruption/restart, the router takes longer to come online than other components causing them to possibly default to completely out of IP range/subnet addresses.
Also, many commercial/installed/live audio systems do not use routers - just managed switches. DHCP wouldn’t work in these scenarios.
I have never in my career worked on a commercial/installed system where static IPs were not used for the above reasons.
I carry a USB Ethernet dongle which is addressed in Windows to be 192.168.1.254 (or any other xxx.xxx.xxx.254) to have access to these systems. 254 is usually blocked off for remote/maintenance access on any professional/commercial network.
How to recognize a professional product? It doesn't have ’Pro’ in the name...
True, often they do... however GPIO (General Purpose Input/Output) is generally only seen on pro amps.
JSmith
I did not because it would require using phoenix connector at one end. I did not feel like cutting one of my XLRs in half. :) Seeing how digital didn't make a change, I suspect XLR performance would be similar, sans that mains spike.
You can tell from connectors in the back. Lack of controls in the front. Inclusion of a fan, etc.
I am not talking about using it with DHCP. But getting into it on first power up.
With DHCP, you can find its IP address and connect to it. No screwing around with IP addresses of the source. Once there, then you select a static IP address on your existing network.
Above is how a ton of gear works today. Or else, provide an app that finds it using broadcast protocol. A web interface with static address set to some random number is next to useless.
As I explained above, of course you want to run the device with static IP address. But on first power up, you want to be able to see the device instantly to configure it. For this, DHCP should be the default. You can then use a port scanner (or in my case Unifi dashboard) and find its IP address and connect. Then you can give it the proper static IP address you like it to have, not the random one they have selected.
That is not how it works in practice for most companies today, they want a device with a MACadress so the system engineer (what is my job) can assign a static ip on the central DHCP for it before it comes on the company network. You don't program a static ip in the device, you assign one on the router with the mac adress of the device so when the device comes on the network it get's it's static ip from the central dhcp. So when you connect it the router already knows it, knows what policies are needed for that device and so.
An active DHCP on the device itself means you need to connect to it direct to disable it and let the dhcp of the company network do it's thing otherwise you get IP conflicts in which case IT security systems will block the device.
It's good when it has it's own DHCP for when there is no central one, but it should be disabled from the box for most cases where this kind of amps are used (in company media rooms) or at least disable itself when they notice there is another DHCP on the network
There is no DHCP server on this amp for wired Ethernet. So this (dual servers) is not an issue. When I said DHCP, I meant it as a client, not server.
That aside, yes, you would want to use IP reservation in your DHCP server to assign it a static IP (assuming your router supports this). But again, that is after you have brought up the unit to talk to it. And for that, you want it to initially get the unique but random IP address from your DHCP server. Once there, you can then do the reservation on your DHCP server and configure the amp with the same IP address.
Having a programmed, default static IP for initial configuration is extremely common in the IT world and is how I actually prefer it. A device that comes out-of-the-box with DHCP enabled and no default IP is generally more of a pain to deal with in my experience.
Anyway, this is an extremely interesting product. Despite Amir's conjecture that this is using class AB amplification due to the well-behaved THD+N vs. frequency graph, the specs say this is class D and may in fact be a custom designed class D solution? These would be excellent in an AVR...
Thank you for the review Amir. I was the one that sent the unit in to have it tested because this would be a wonderful amp for DIY active 2 way speakers with DSP + 4 channel amp in one small box. This performed well and looks to be a great option for many use cases.
I want to note that this amp has a special architecture having separate 250W power supplies for channel 1 and 2, and another 250W supply for channel 3, 4. So doing 2 channel driven test on channel 1 and 2 will only get half the total power because it only uses PSU 1 and not PSU 2. So this amp should be capable of 2x250W when used in a non standard way of running on channel 2 + 3.
This is really exciting for DIY speakers because this is one of the exceedingly few products that have both and amplifier and DSP in one box at a reasonable price, and I'm glad to see the amplifier is actually well designed. The DSP is better and more feature rich than DSPs from miniDSP and Hypex, so this is quite an awesome combo.
Wish I'd kept my mouth shut! LOL :):)
PS : And you do make a good point. Static yes but you have to find it first - is my amateur take!
We are a funny bunch - we do get hung up on the strangest points ! :)
