You can’t demo them anywhere yet as they haven’t been released!
Sure! I mean once they are avaible. The official ascilab distributor for Germany is audiophonics who don’t offer a trial period. According to German law I could withdraw from the purchase within 14 days after receiving them but not a big fan of ,,abusing“ the return policy.You can’t demo them anywhere yet as they haven’t been released!
Can you please, in short words, tell the difference between the A6B and the future S6B?As I expect, S6B(Full Purifi driver 2 way passive speaker) will be released first. Then C6C(Active Cardioid 3 way bookshelf) and C8T(passive floor stander). S6C will be much later as current plan.
The A6B has a purifi woofer but no purifi tweeter with a custom waveguide. The S6B has all purifi drivers and I believe larger passive radiators.Can you please, in short words, tell the difference between the A6B and the future S6B?
S6C in 2026 or 2027?
thorsten
Hm, these differences would be sooooo tiny, given the fact that the original tweeter with all his special capabilities (running down to 1100 Hz, with increadible sound pressure capabilities and nearly no distortion even at 96 dB) is not something I would like to be replaced by a Purify tweeter, which could be only more costly but really better???The A6B has a purifi woofer but no purifi tweeter with a custom waveguide. The S6B has all purifi drivers and I believe larger passive radiators.
If you really want to know: wait for the measurements ;o)Hm, these differences would be sooooo tiny, given the fact that the original tweeter with all his special capabilities (running down to 1100 Hz, with increadible sound pressure capabilities and nearly no distortion even at 96 dB) is not something I would like to be replaced by a Purify tweeter, which could be only more costly but really better???
I do think there was a measurement somewhere in this thread. It didn’t have a cut out in the vertical dispersion which means the sound quality sweet spot is wider and the directivity was somewhat smoother and wider all the way to above 15k which all together can make quite a difference in sound perception. But of course hard to tell without actual listening.Hm, these differences would be sooooo tiny, given the fact that the original tweeter with all his special capabilities (running down to 1100 Hz, with increadible sound pressure capabilities and nearly no distortion even at 96 dB) is not something I would like to be replaced by a Purify tweeter, which could be only more costly but really better???
The waveguide is custom designed for the SB acoustics tweeter.The A6B has a purifi woofer but no purifi tweeter with a custom waveguide. The S6B has all purifi drivers and I believe larger passive radiators.
The SB Acoustics tweeter shows some very slight compression at 95 dB around the crossover region since it is crossed very low.Hm, these differences would be sooooo tiny, given the fact that the original tweeter with all his special capabilities (running down to 1100 Hz, with increadible sound pressure capabilities and nearly no distortion even at 96 dB) is not something I would like to be replaced by a Purify tweeter, which could be only more costly but really better???
You may think of it as 'abusing' the return policy, but the reason the right of return exists in the distance selling regulations is that you can't assess the product in person before purchase.Sure! I mean once they are avaible. The official ascilab distributor for Germany is audiophonics who don’t offer a trial period. According to German law I could withdraw from the purchase within 14 days after receiving them but not a big fan of ,,abusing“ the return policy.
I think it's only abusing the system if you're constantly trying things out. What's worse is when some use the clothes they have purchased and THEN send them back (fast fashion)You may think of it as 'abusing' the return policy, but the reason the right of return exists in the distance selling regulations is that you can't assess the product in person before purchase.
How would that appear on a distortion chart? What kind of distortion chart would it appear on? I mean on the acoustic measurement of a speaker unit.perhaps : lower distortion, wider dispersion, much less hysteretic magnetic distortion. time will tell.
Generally H3 of mass controlled range reflect magnetic hysteresis distortion.How would that appear on a distortion chart? What kind of distortion chart would it appear on? I mean on the acoustic measurement of a speaker unit.
I think there's a translation error, I don't understand the expression "mass controlled range".Generally H3 of mass controlled range reflect magnetic hysteresis distortion.
Above FsI think there's a translation error, I don't understand the expression "mass controlled range".
Do you mean h3 levels above Fs?Above Fs
