AsciLab speakers are about to launch
Amazing! Really impressed with the A6B speakers.
They are fantastic!
The stands are a pair made by Deni Mesanovic ( of Mesanovic speakers/microphones) they are useful just for bringing the speakers up to more or less ear level, and yes they come in white.
Tell us more! What were your previous speakers?
The speakers are used in a family room and have had various speakers in the past. The previous speakers were Revel M106+SVS subs and for a short time had larger Revel floorstanding speakers in the space. I primarily purchased the a6B due to the superb objective measurements of the entire line AsciLab speakers that's been measured. For my subjective feedback, it's hard to describe. It's like a goldilocks speaker for my preferences where everything seems to sound just right-Clear balanced sound and goes surpsingly low.
Great! It will be helpful for us to share your impression.
I thought I was close to being done in this audio hobby but now I'm so curious about the other speakers on your product roadmap. Particularly the floor standing speaker and the models that'll connect to the bass box. Not sure if I should thank you or curse you for drawing me back into this hobby :).
Your future might be Cardioid Curious.
Thanks for your comments. Cool to hear again impressions from someone coming from already pretty darn excellent speakers, and comparing to AsciLab models in room.
What would you say are the key differences between the A6B and the fidelia?
Apart from £2k!
The A6b are like three way speakers, dynamics, SPLs bass extension, clarity they are superb imho.
Will there be an option in the future for an active version of the A6B? I think I remember, that the rear plate with the crossover should be exchangeable with a active module....
I hope there will be, a passive pair of A6Bs are with Phil Ward of SoundonSound magazine which is primarily ‘pro’ audio based, an active A6B would arguably be more suitable for the Pro user .
I understand this is to do with the tweeters?
... like mentioned in this post?
Does this mean the tweeter used in the F6B(s) models doesn't get this check/adjustment?
I might have understood that it's somewhat critical to get the ~1khz crossover that the F6B series does have in common with the C6B...
Got a reply about this from AsciLab on another thread - posting it/link here in case anyone is reading and interested.
"Currently we don’t apply that QC for F series.
F series tweeter has no acoustical issue without it. You can see how low the distortion from the Amir’s review."
It is DSP active MTM/Cardioid model. Still in progress. It was simulated response but I assure there will be similar result.
Can you tell us, if the DSP will internly work with 48 kHz or will it work with 96 kHz or even 192 kHz?
Or can it even manage DXD (352,8 kHz - Studio Standard) without intern downsampling?
