staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,566
- Likes
- 27,666
See here: https://www.audiosciencereview.com/...eakers-are-about-to-launch.54794/post-2320344Is there going to be a c5b?
I’d like to recommend to listen at acoustic center “A”. But it won’t be sensitive about the ear height. Our vertical dispersion is quite linear and wide than average.@AsciLab
Hello, I have two questions regarding the C6B.
Question 1: What is the optimal listening height for the C6B?
A. At the midpoint between the tweeter and woofer (the “acoustic center” you mentioned before)., or
B. At the same height as the tweeter
Question 2: If measured from the bottom of the speaker, what are the respective heights of A and B in centimeters?
Thanks in advance
I think it looks more harmonic like this.
What is the reason for not using the 8 inch ceramics?
Don't worry about that with these speakers. I won't tell you what I am doing while listening to music but my ears are all over the place and they keep sounding good!@AsciLab
Thanks in advance
How important is "non-magnetic" in terms of sound quality?ㅓ
Yes. 2-way crossover for A6B.
PP cab, air core inductor, non-magnetic heat sink resistor.
Non-magnetic means no hysteresis.How important is "non-magnetic" in terms of sound quality?
Is there any technical documentation of this issue? Magnetic hysteresis doesn't seem like it should have any impact on audio signals, but I wouldn't mind being proven wrong.Non-magnetic means no hysteresis.
Iron components makes hysteresis and it affects the odd harmonic distortions.
Many of good drivers use a lot of copper or alu in the motor to get more linear Le and lower distortion. But what’s the point if there is iron material through the signal path?
See the Purifi papers, very interesting.Is there any technical documentation of this issue? Magnetic hysteresis doesn't seem like it should have any impact on audio signals, but I wouldn't mind being proven wrong.
Hm, if I'm understanding correctly this is more due to the generation of spurious voltage than the sort of magnetic hysteresis the Wikipedia article is talking about.See the Purifi papers, very interesting.
This Thing We Have About Hysteresis Distortion
purifi-audio.com
Some Speaker Problems That Needed Solving
purifi-audio.com
Seems to go off into subjectivist la-la land at the end, even if the rest of the article seems to be rather technical and describing a real phenomenon. I'd need to see the results of some blind ABX testing to verify that this is an audible concern. I've certainly never noticed a "blanket of fuzz" from any of the speakers I've listened to, many of which I'm sure are using iron-core inductors.Hysteresis distortion isn’t something that we simply decided to big up in search of a USP. It’s very real, very different from what you’d expect and not at all subtle. It takes the form of popping or crackling noises that go off at almost but not entirely random moments. You can’t rely on masking to render it inaudible because cause and effect are not coupled in time and the distortion level tracks the signal level. It is not like normal distortion that the ear just files away as coloration, or can otherwise get used to. Left to its own, hysteresis produces a recognizable grainy texture in the sound, a blanket of fuzz that always stays just this side of audible, taunting and infuriating like an itch you can’t scratch.
I have some experiences of comparing air core coil and iron core coil. I was using them for midrange and I matched the curve same each other. Then I recorded two of them separately to compare speedly. It was quite interesting. Though they had almost same response with only different H3 distortion, the sound was quite different. As subjective words, air core one has smooth, moisture, transparent sound. But the other one using iron core coil has more aggressive, thin, harsh sound.Hm, if I'm understanding correctly this is more due to the generation of spurious voltage than the sort of magnetic hysteresis the Wikipedia article is talking about.
However, the final paragraph of that Purifi article makes me groan:
In any case, I fear I may be driving this thread a bit off topic.
So to be clear, the measured difference between the two coils was the amount of H3 distortion?I have some experiences of comparing air core coil and iron core coil. I was using them for midrange and I matched the curve same each other. Then I recorded two of them separately to compare speedly. It was quite interesting. Though they had almost same response with only different H3 distortion, the sound was quite different. As subjective words, air core one has smooth, moisture, transparent sound. But the other one using iron core coil has more aggressive, thin, harsh sound.
I know these description can be allergic to someone, But I believe you will have similar result if you test it. I’m not talking about immeasurable magic. It can be obviously seen in measurement.
Mainly, yes. Odd order harmonics.So to be clear, the measured difference between the two coils was the amount of H3 distortion?
That was a very exciting read to get to the solution! I guess I'll replace the steel nuts and washers in my binding posts...We also have the two famous threads about it.
(link1, link2)
View attachment 471084View attachment 471085
Not me.Does anyone else think some wood veneer (or wood effect) options would be a nice addition to the available finishes?
