boxerfan88
- Joined
- Oct 23, 2018
- Messages
- 1,333
- Likes
- 1,667
AsciLab ads...
AsciLab ads...
i have searched and simulated a number of such configurations in Comsol FEA. Yes, you can kill the mode. however, all these methods create a new mode at a lower frequency which is even harder to damp out. Maybe i have not found the right way. There is some theory about poles and zeros need to alternate and this is what forces a new pole below a deep nullRegarding standing wave in larger enclosures: have you considered an internal Helmholtz absorber to eliminate it?
AsciLab C8T is developing.
I’m satisfied with the first result.
The woofer position will be a bit differed to get more smooth response.
Cause the bass roll off is quite smooth and deep, in room response will be easily down to 20-30Hz.
40 to 80Hz -6dB/oct, 20 to 40Hz -10dB/oct.
This speaker has more deep controlled directivity down to 200Hz. It’s rare to see as a passive speaker. It’s almost cardioid speaker.
How do you guys think about this beast?![]()
Yes. Mean sensitivity is 85dB.Early performance looking really good!
Is it a sealed box with 8" push-pull side-firing woofers?
How's the C8T speaker sensitivity looking like? 85?
Didn’t test C5C yet.Can I ask about the C5C...are there any measurements, and when might they be released?
Is C6C still the next release?Didn’t test C5C yet.
Too busy to develop several project for now.
Sorry.
No problems.Didn’t test C5C yet.
Sorry.
Looks cool.Is C6C still the next release?
Anything you can share with that speaker?
I love it. And the directivity control is amazing.How do you guys think about this beast?![]()
Agree. With a narrow cabinet like that, probably more like 800Hz?Baffle step starts much higher than 2 or 3 hundred Hertz.
You're thinking 2 1/2 way (2 bass/different LPF), not? , but mid adapted to bafflestep (let's say 85 dB instead of true 87 dB without correction) will allow to adjust bass to this SPL tuned to lower f-3/6.Agree. With a narrow cabinet like that, probably more like 800Hz?
And this really answers my question because why use a driver to only reproduce 800-1KHz.
Are you trying to drive all the other speaker makers in the world out of business? Cause it looks like you're succeeding.View attachment 470432View attachment 470426View attachment 470427View attachment 470428
A 2.5-way config does indeed counter baffle step loss, but I was wondering if the 3-way design here could achieve the same by crossing the mid-bass before the baffle loss takes full effect. This assumes that the SPL from the 2x 8” drivers is suitably high to match the SPL of the mid-bass.You're thinking 2 1/2 way (2 bass/different LPF), not? , but mid adapted to bafflestep (let's say 85 dB instead of true 87 dB without correction) will allow to adjust bass to this SPL tuned to lower f-3/6.
