- Joined
- May 30, 2024
- Messages
- 903
- Likes
- 6,957
- Thread Starter
- #921
We should design our own waveguide.What directivity profile does the Purify tweeter’s waveguide allow? Does it suit your brand design goals?
Yes! Would love a sealed 2-way for subwoofer-based systems.Very nice! Looking forward to see the product with complete purify drivers..
I think the cardioid is a two way, sort of.Yes! Would love a sealed 2-way for subwoofer-based systems.
Still, I have more modest ambitions.I think the cardioid is a two way, sort of.![]()
Yes, All-Purifi cardioid will be incredibly expensive if that's what you're aiming for.Still, I have more modest ambitions.![]()
Only a little hole at the back. That hole is connected through long channel to inside. It reduced air pressure change, DC.Is the back of the Purifi tweeter open, or is that just a dimple? Maybe my screen is playing tricks on me.
No. It only allows to be affected by close to DC signal. For sealed enclosure, it’d better have tweeter chamber. For ported mostly don’t be affected.Got it, so it can share volume with the woofer.
Right?
MTM design was needed to achieve bass capability and optimized cardioid pattern.@AsciLab: If I may ask, what was your design decision for the d'Appolito design and the (therefore?) relatively narrow vertical directivily in the 1kHz range?
Unbelievably quick and helpful responses you offer, AsciLab- good on you.MTM design was needed to achieve bass capability and optimized cardioid pattern.
It leads to have narrow vertical response over 500 to 1.5kHz, but it’s a good feature to reduce floor/ceiling bounce If you once set the speaker height correctly.
And Our vertical dispersion better than most similar size MTM design. This is the latest optimized vertical response.
View attachment 432223View attachment 432224
Not quiet convincing: dip in x-over region, but not following above frequencies with only little attenutation to baseline.MTM design was needed to achieve bass capability and optimized cardioid pattern.
And Our vertical dispersion is better than most similar size MTM design. This is the latest optimized vertical response.
Wide 2-3kHz vertical dispersion is affected vertically wide baffle. Vertically larger size waveguide can help the tweeter get more smooth vertical dispersion. But it makes worse due to increase midrange C to C. In result the vertical lobbing gets worse.Not quiet convincing: dip in x-over region, but not following above frequencies with only little attenutation to baseline.
Perhaps some vertical directivity adjustements via adjusted waveguide/horn?
Or some 'I' shaped tweeter.
Hi Keith, its me (Simon)! We already discussed the prices directly after I wrote my question so all good thanks.Which model A6B, C6C, A6C, I don’t believe prices have been finalised just yet.
