AsciLab speakers are about to launch
Yes those are they, there was gloss Modern Grey and gloss Metallic which was darker almost blue very smart.
I am hopeful AsciLab will increase their range of colours in time.
The problem with the actives is that they only have 1 year warranty with no idea as to repairs to the amp module price after the warranty expires.
This is the most common failure on active speakers apart from blown drivers.
Has this already been discussed?
I will only buy passives from ascilab.
Is there an update to the c8t price and availability?
Repairs are likely not economical. Fortunately it is an off the shelf module that you can purchase and replace yourself.
Its a valid concern, actives are not for everyone.
The good thing with Ascilab is the parts are all easily available and replaceable.
The plate amp is 3 amps plus dac, crossover and some dsp all in one. Its been available for yesrs and failures seem rare.
To do a passive C8C you would need a 6 channel dac/dsp/pre and 6 channels of amplification. Double that if you add passive BX8C.
The C8T looks a great speaker, but wont perform the same. Not sure what the amp requirements will be? Suspect it will be similar to the amp modules in the C8C.
I'm on the fence about getting the S6B, how much is it overall improvement over a6b?
See Ascilab's measurements:
The S6B has slightly taller and wider directivity.
No difference in frequency response, headroom, THD, or Multitone distortion.
How much does the amp module cost?
How much work is replacing it.
Can you provide the hypex model number.
Honestly I don’t know, but I can ask,as I mentioned I haven’t needed to change any Hypex amps, D&D8C, was literally unscrewing, replacing with only three ‘clip’ connectors one of which was for the front LCD.
Replacement takes 10 minutes and no special knowledge.
C8C uses a Hypex FusionAmp FA253
Much lower requirements. With the increased size, Ascilab can select more power efficient woofers. I believe that at some point they said 85 dB/W, that's a few dB/W more than in the C8C.
I was looking at the Genelec 8380 measurements and was reminded of the old C8T. They look decently similar, at least in terms of normalized horizontal directivity. I don't think I should share more, given that Erin's measurements are paywalled. They will be made available at some point and Ascilab will share the new C8T as well, and hopefully both will find their way to spinorama.org for direct comparison.
Yes. All the speaker should be connected to the PC. And the phone should be in the same WIFI with PC.
Hi Ascilab, I'm trying to decide if the f6b is good for me. I want to buy f6b but what I wanted is a soundstage improvement from my kefs for better immersion and afaik the f6b has similar dispersion (+- 50) to the kef q150, with the c6b having wider dispersion. Does it mean the soundstage will be just the same or smaller? But also I'm using it in a non-ideal room with the speakers close to other objects like my pc so maybe it's not good too have too much dispersion. I use it maybe 1-1.2m from my pc.
Can you sell me on what improvement you think the f6b will give me considering I like enveloping soundstages?
Here you go:
F6B and C6B have identical directivity.
Q150 has pretty much identical radiation width/height, just slightly more coarse and w/o the vertical crossover error of the Ascilab's.
Not sure what immersion means to you, but if it's envelopment that you're after then neither Ascilab speaker will be a noticeable upgrade.
Here you go:
View attachment 564174 View attachment 564175 View attachment 564176
have you heard the two? Afaik erin gushes about the c6b's envelopment.
is there a release date for the controller app AsciLab is working on (macOS version) to replace HFD?
