- Joined
- May 30, 2024
- Messages
- 937
- Likes
- 7,113
- Thread Starter
- #3,981
Hi all,
Here's an update on the controller I mentioned earlier. Following the macOS version, we're now also developing a Windows version with the same features.
It isn't ready for release yet, but it has come a long way, so I'd like to show where it stands and hear your thoughts before we finalise it. Screenshots attached.
Working in our internal build now
Multi-speaker management
- Connect several FusionAmp-based speakers at once, switch between them one by one, and give each a nickname. Identify flashes the LED so you can see which physical speaker you're controlling.
- Groups: link amps (e.g. a stereo pair) so volume, mute, input and optionally preset move together. Volume moves by the same step on every member, so an intentional level offset between them is kept.
Everyday control
- Volume, mute, input and preset, with a Max Level Limit that caps everything the app can raise (volume, preset offsets, preset switching, volume on start).
- A compact quick-access controller in the menu bar (system tray on Windows).
- Phone control: scan a one-time QR code on the same Wi-Fi to control volume, mute, input and preset from a phone browser, with no app to install. It runs over plain HTTP, so it's meant for trusted home or studio networks only. The level limit and all other settings stay in the app.
Device settings
- Per-preset volume offsets and inputs, digital channel select (L / R / L+R), auto power-off with signal detection, wake on line, volume on start, and shutdown mode.
- Device info: firmware, FIR tap counts, amp temperatures.
EQ, crossover and delay (previously on our "waiting" list)
- 9-band console EQ per preset, with REW biquad filter import (Hypex model only) and a warning before writing if the combined boost exceeds +6 dB.
- Crossover: Butterworth 1st–8th and Linkwitz-Riley 2nd–8th order, built as cascades of first- and second-order sections.
- Added delay per preset in 0.1 ms steps. All channels move together, so the internal alignment is kept.
What's next
- It isn't settled yet whether every function above will make it into the public version. We're still bug-testing, and anything that isn't stable may be left out. We're also working out which advanced functions (EQ, crossover, FIR switching) users get, and how, so the factory voicing can't be lost by accident.
- Since the app can upload dedicated preset packages, a factory reset will always be possible with a file we provide if needed.
- Many of the descriptions still read like developer notes. Awkward or unclear wording will be cleaned up.
If there's something you've missed in HFD, or anything you'd want (or not want) in a user-facing controller, please let us know here. Thanks!
