AsciLab Directivity & Room Response — Beta Now Open
Directivity · Boundary Interference · Room Mode Simulator
We're releasing a web app that lets you simulate, in advance, how an AsciLab speaker will actually respond once it's placed in your own room — based on real measured directivity data. Only some products are selectable for now; we plan to expand coverage to the full AsciLab lineup.
This is a beta, and designed by Claude vibe coding, so please feel free to report any bugs or suggestions. We'll incorporate them into the next version.
This release is optimized for desktop screens. It is not a substitute for real-world measurement; the goal is to make it easy to visualize room modes, early reflections, and the differences in reflected-sound patterns caused by directivity, within a simplified environment. Enjoy.
1. Based on real data measured with the Klippel NFS
The source data behind the simulation is 3D directivity data measured directly from AsciLab speakers using the Klippel NFS (Near-Field Scanner). Because it's built on actual measurements rather than simulations or estimates, you can trust what you're seeing.
2. Enter your room, speakers, and listening position exactly as they are
Room dimensions, sofa or desk listening position, speaker coordinates, toe-in, and tilt — your actual setup, reflected as-is.
3. 3D room simulation based on AsciLab products
Select a product and the measured directivity data is used to visualize the 3D radiation pattern (balloon) and the first-reflection paths.
4. Six analysis views
3D Room / Plan · Horizontal / Section · Vertical / Summed Response / Phase · Group Delay / Acoustic Center by Frequency
5. Boundary absorption included
Set absorption coefficients (α) for walls, floor, and ceiling individually, along with reflection order, for results closer to your real room conditions.
6. Dip diagnosis
Dips in the response are detected automatically, classified as minimum-phase or non-minimum-phase, analyzed for cause (room mode, SBIR, LBIR, etc.), and assessed for whether EQ correction is viable.
7. Boundary interference analysis
Per-wall path-length difference, delay time, and the constructive/destructive frequencies with their dB values, shown in detail.
Try out Artifacts created by Claude users
claude.ai
