Looks like the F3 is around ~75Hz for the F5CTR?
Yes. F3 75Hz, F6 64Hz, F10 50Hz.
@AsciLab As it looks in this picture this prototype uses the same tweeter as in the C6B. Will you use it in the final product too or does the speaker will get the same tweeter found in the F6B/F6Bs?
The acoustic parameter are the same each other. So, the final product will use the same tweeter with F series.
regarding the unusually low crossover point (1.1 kHz) combined with the custom waveguide on the alumina ceramic tweter
how did you balance horizontal ,vertical directivity against harmonic distortion from the woofer in the overlap region?
did the NFS measurements lead to any specific tweak to the waveguide profile or filter slopes in order to keep the DI as constant as possible?
thanks
Yes. NFS helped a lot when we were developing our waveguide and basic crossover schematic.
As you see, we use unusually low crossover point but the overall distortion or dispersion don't look messy or fragile.
Due to our deep and big waveguide,the tweeter could have a lot of loading so though acoustic crossover looks quite low, eletrical crossover doesn't push the tweeter too much.
I would certainly be appreciative if the 3 way has this
Unfortunately It won't. 3-way version must be too heavy to use Vesa bracket.
Are there any plans to design a mini-monitor of sorts that can be used for Atmos/surrounds in a HT setup?
You can use F6Bs.
Another question. Would a standard AVR (I have the X3700) be able to adequately drive 5 Ascilabs speakers? (let's say 3 C6B's in the front and 2 F6BS's in the back) provided I cross them at 80Hz and have dual subwoofers? I understand they're all 4 ohm speakers with dips even lower.
Many people worried about the driving possibility of some amps due to our low impedance(not so low though, only some area of C6B).
So we tested with a few of mini amplifiers like Topping PA5ii and there wasn'tany issue to driver our speakers with enough volume, actually quite high volume.
You don't have to worry about to drive with your AVR.
