AsciLab speakers are about to launch
With the BX8C, you can test things using the controls; one user posted what happens, but many others haven't—myself included :)
Difficult to compare with any real validity unless you have two ‘identical’ designs one cardioid one not.
The closest to that I have heard is when D&D made their 8M ( monopole ) model which had the same volume enclosure same mid/treble as the 8Cs, that comparison convinced me that a cardioid response was worth pursuing.
In terms of AsciLab, if we compare A6B/S6B to C8C, the cardioid design just sounds separate from the room, just that bit clearer and the addition of the BX8C takes that extra clarity into the lower bass.
The BX8C modes P1 (max SPL) and P3 (extended cardioid) can give at least an idea about the effect of cardioid directivity in- room. You notice less SBIR influence (excess GD peaks, also reflected in frequency response).
I am currently running my BX8C in P2 mode which is a good compromise (improved excess GD and SPL in bass region).
Nice, thanks for sharing your experience!
Would you be able to also share REW measurements at your MLP with the C8C + BX8C in the latter's P1, P2 and P3 settings? Would really appreciate if you could give an insight in frequency response (1/24 smoothing) and THD amongst the three cardioid options; without any room-EQ applied. :)
I will certainly do that. Wanted also share what Dirac ART does to the bass below 150 Hz, compared to manual PEQ.
Allow me some days - until next weekend (will be travelling this weekend).
Unfortunately I have a strange distortion issue with one of my C8C (potential defect), so measurement results might be screwed up until this is sorted out. I am already in contact with Ascilab about this.
Reactions: 829
Amazing! No worries, take your time. Am grateful for the effort.
Is it an issue that could be fixed by re-applying the latest filters to firmware V1.1? But am sure Ascilab would try this first. :) Also Hypex have their own update for the FA253. But yes, it makes sense to get this sorted out first. If you exchange the L with the R C8C; does the distortion stay with the same speaker; i.e. can you exclude it's room-induced distortion or maybe by external DSP?
Additional Dirac ART measurements would certainly be great! Especially in terms of THD changes and of course decay reverberation times.
I am working with Ascilab in isolating and diagnosing the issue. Let's see.
Sneak preview without showing measurements after one day initially setting up and playing with Dirac ART:
- SPL response below 150Hz will look very much like your target curve, i.e. no resonance peaks. Some dips might remain. All at MLP measurement position (have to investigate other positions as well).
- SPL response L+R looks also "perfect", i.e. L + R phases are matching well. Did not manage to get this result by manual PEQ.
- Spectrogramm looks pretty much like a straight line (both GD and decay).
- GD rises at Dirac ART high pass (20Hz).
In a nutshell, measurements look visually much better with ART than with manual PEQ. Sound wise, however, differences are more subtle than they might look ok on the measurements and I currently see no strong reason - in my specific setup - to use Dirac ART (added cost and complexity). My C8C and BX8C are so clean and impactful - in my room and to my ears - that I could live perfectly without any subs. Other rooms, however, might present different challenges justifying a distributed sub setup.
Thanks, that's very interesting, in my setup with C8Cs, 3 Subwoofers, and two strong side surrounds giving additional support, the subjective difference with ART is very clear, but that is to be expected.
Can you explain your subjective impression?
Sorry, I was on vacation. I'll try to explain my impressions (without data to support it):
I have a strong Null at about 40 Hz in my room, which I was never able to correct properly (living room without bass-treatment), the cardioid properties of the C8Cs alone helped somewhat, but only ART has subjectively solved that problem.
Bass sounds also "tighter" and "more" at the same time with ART, certain bass notes clearly sound more resonate without ART turned on. With 3 Subs supporting, bass has also just a deeper foundation than with the main speakers alone. Not sure how to describe that, even though the C8Cs play quite deep alone, I only get the "deep bass everywhere" feeling with the subs.
In any case, since it is also a 7.1 HT-system, I have to use some form of speaker alignment software anyways, and ART is clearly the best I have tried.
Now we are on progress two type of center speakers. 2-way and 3-way. Here are the picture of 2-way version. You can use it vertically too. Both position has very neutral and stable sound character.
For an MTM speaker, the vertical dispersion performance is surprisingly good...
Though if the woofers were upgraded to 6.5 inches, that would be amazing.
I can't wait to buy one! Could you share the cabinet depths for this speaker (and the upcoming 8-inch version)?
Thank you for noticing what we focus on. H and V both those dispersion are very stable and textbook DI proves it. The depth of F5CTR is about 150mm. And there will be an addible bracket for Vesa 100 and screw hanging.
We’ll share about 3-way version soon.
We finally have a name! Any timeline details you can share for the F5CTR or the 3way at this time?
F5CTR will be opened first. Will share the detail timeline after confirming the other things.
Final fine tuning is going on to get a perfection. I can’t wait to share you the whole results. :)
Always appreciate your development updates. I understand the priority for launching the centre channel models, but I wonder if you can update us all on the C8T? You shared a few months ago some preliminary data and it looked amazing.
+1 on the C8T interest…
