AsciLab speakers are about to launch
I can confirm if you set both speakers to master and just use AES everything works, including auto on and auto off.
Cant use master/slave with AES alone.
Got it -
Would using AES between both speakers, forcing input on slave as AES and adding SPDIF for controls work too?
Got it -
I think so. But why do you want to run an extra cable?
Just stick with AES
Isn't there a penalty to running both speakers as Masters, independently of each other?
What penalty? Why do you think this?
Its just about control functions. Does not matter where its done, just get it done the easiest possible way.
Took me a some trial and error but its running perfectly now.
Next step is to tame the 50Hz room mode thats getting way too excited....
I thought that running speakers independently of each other could end up in having volume mismatch or other control-related issues.
You're saying that's not the case - fair enough then. I agree there's no need to over engineer it.
One last question on this topic from me and to be 100% clear: your speakers are still daisy-chained via AES even while they are both set as Masters in HFD, correct?
Yes. You set the volume on both speakers the same value in HFD.
Master/Slave setting isn’t essential.
As AJ said, if you don’t change the device setting often, you don’t have to use that function. It’s more useful when using remote controller. But we don’t think the Hypex remote control is convenient, so we hope you guys use well made source player or pre amp.
At present, labor costs account for a very large portion of the manufacturing cost of the C8T. We are actively considering ways to reduce this, and we believe that some level of price adjustment may be possible once the planned automation equipment is successfully implemented.
However, since we need to evaluate the actual results after implementation, the currently announced pricing is based on the existing labor cost structure. We are hopeful that the automation system will be fully operational before the official release of the C8T.
I was reading up on the C8T.
Do you think it would be possible to offer the C8T as a diy kit?
There are no plans to release a DIY kit for the C8T.
* I've corrected the comment. It is C8T, not C8C.
I guess a big ship arrived in Marseille, since they also started shipping the C8C to customers ;)
Don't want to be the party breaker but seems there still delivery challenges, I assume it is because I ordered the C8C and BX8C together? Moved from March -> May -> June26.
Audiophonics France:
Dear customer,
Unfortunately the supplier delayed the arrival of your missing product to the beginning of June. Would you like to wait or change your order? We are sincerely sorry for the inconvenience caused. Pending your response, we remain at your disposal.
Best regards,
Sébastien FOURMOND
Responsable Administration des ventes - Service clients
BX8C comes later, that has been known, see Ascilabs post on previous page. I only have the C8C ordered, and it is scheduled for delivery tomorrow.
As they asked you if you want to change your order, I assume you might still get the cardioid earlier? Sounded a bit like it tbh. Good luck!
Basically I have the option to:
  1. Cancel the C8C + BX8C order
  2. Revise" my order" to exclude the BX8C -> this should expedite the C8C being send quicker
  3. Await the arrival of C8C and BX8C together, estimated for June now.
